Results 1 to 2 of 2
Thread: Joining modules of Astec MVP series power supply
    Mar 2011
    I have an Astec MVP series power supply with 4 modules installed.
    24v 15a
    5v 35a
    15v 14a
    15v 14a
    I am currently using the 24v tap for my HobbyCNC controller but I just ordered a Gecko G540 and I wanted to run with more voltage. My current steppers are only 2a.
    Can I connect the + of the 24 to the - of the 15 volt and then connect to the -24 and +15 to "join" them to get 39v 14a ?
    If that will work can I also join the 5 volt to get 44v ?
    Thanks in advance...
    Eric
    PS... This is my 1st post so I can't add the URL but a google search on Astec and MVP will give you a link to a data sheet.
    Dec 2005
    Hi Eric.
    I was wondering the same thing with an Astec PSU that I got off ebay. It has two modules in parallel, to output 42v at 25A. Along with an 8v module.
    I found this: https://www.powerconversion.com/asse...05_appnote.pdf So it looks possible.
    Shaun
    my x2 conversion ------> http://www.cnczone.com/forums/showthread.php?t=36403
  1. FANUC Alpha Series power supply input power limits
    By tcom-frazzled in forum General Metal Working Machines
    Last Post: 01-17-2012, 12:07 PM
  2. Need Help!- Power supply ASTEC VS1-D9-03 (-CE)
    By GMS in forum Want To Buy...Need help!
    Last Post: 07-31-2010, 06:42 AM
  3. Newbie- Series I power supply
    By marvfrankel in forum Bridgeport and Hardinge Mills
    Last Post: 02-24-2008, 09:08 PM
  4. Power supply for Bridgeport Series II
    By Billy Bird in forum Bridgeport and Hardinge Mills
    Last Post: 01-05-2006, 08:58 PM
