The question is a bit general but for the most part, but I usually link them with a continuous conductor but this assumes at least one or both have a entry connector of some kind?
The one down side is if the entry connector is covered and not a screw terminal, it is tricky to monitor a signal if you have to.
I would not connect two systems with which were not capable of being unplugged somehow, i.e. soldered connection etc.
LinkBack URL
About LinkBacks
