Results 1 to 7 of 7
Thread: How to make Riveted Vias, Perfect PCBs with Toner Transfer
    Nov 2011
    I've been working on an A3987 stepper driver board, and have figured a way to make copper riveted Vias. This allows for very good thermal transfer to the bottom side of the board.
    Rivets are made using a special cutter (inexpensive, available at Amazon) with a DIY spacer inserted into it so you can produce consistent sized rivets, with square cut ends.
    I describe this at paulwanamaker.wordpress.com I will be adding a couple more pictures.
    I also have an article about making perfect PCBs using the Toner Transfer Method.
    Enjoy!
    Registered Drools's Avatar
    Feb 2009
    Interesting method thank you very much for sharing.
    Thank You.
    Registered doorknob's Avatar
    Jan 2010
    There was a recent post on this forum that suggested using HP glossy presentation paper (IIRC) for toner transfer:
    HP Laser Presentation Paper, Glossy, 8 1/2" x 11", 32 lb., Ream | StaplesŪ
    I notice from your list that you have tried one type of HP paper, but was it the same as the above or different?
    Nov 2011
    Doorknob;
    The HP paper I used was different: HP Brochure Paper #Q6611A.
    I have updated the page, thanks.
    If you try the Glossy Presentation Paper let us know how it goes. You want a completely clean release. Otherwise you are better off buying some Press-n-peel for near the same amount, or making your own.
    I will post how to make the paper tonight on my website tonight.
    Nov 2011
    I have updated the page about DIY Copper Via Rivets at PaulWanamaker.Wordpress.Com to include pictures of the cutter with the spacer used to make the copper rivets.
    Nov 2011
    I have added a page about making your own dextrin coated transfer paper for the toner transfer method.
    Jan 2005
    Toronto, Canada
    The results look very good. I use the HP Presentation paper mentioned above.
    Toner Transfer, excellent results
    It resulted in perfect transfers also, but mine had a white coating on the toner. Perhaps I ran it through the laminator too many times. Others reported that theirs transfer clean.
    1. Replies: 1
      Last Post: 03-13-2012, 03:44 PM
    2. My first Toner Transfer 2 side PCB!
      By H500 in forum General Electronics Discussion
      Last Post: 07-07-2007, 12:51 PM
    3. Toner Transfer Failure
      By lurch in forum General Electronics Discussion
      Last Post: 04-19-2005, 12:58 AM
