Hey guys, I'm in the need of some help. I'm about to spend the day in a field I'm a total newbie; wiring my cnc router. I've got a G540 so the wiring in it self should be pretty much plug and play.
Although I want a couple of switches on the door of my enclosure. One master ON-OFF switch and an E-STOP. The master switch is going to control the 230V line in. Being an EBAY item there was no manual or diagram, but it's marked with odd numbers on one side (1-3-5-7) and even numbers on the terminals on the other side (2-4-6-8). I have three leads on the wire, live, neutral and ground. How do I wire this up? Should the ground wire (goes to a central grounding point) also run through the switch or should I bypass the switch?
One down, one to go. I can't quite figure out what is the NC and C on this E-STOP, anyone tried a similar one before? What goes where?
Also, I want to use two e-stop switches, one located on the door of the enclosure (this one) and one situated on the other side of the table. How should I wire this up? As stated I use a G540.
Any help would be greatly appreciated guys. Thanks.
LinkBack URL
About LinkBacks
