I have no experience (yet) with Mach3 PWM spindle control, but nevertheless here's a question:
The manual to which you linked gives example G codes for setting the desired output voltage (minus a diode junction voltage drop). For example, : G96 S900 to give 9 volts output.
Have you tried that with different output voltage specifications from 0 to 12 volts, and if so, did it give you the expected results?
LinkBack URL
About LinkBacks
