11-16-2005, 10:56 PM
there are, literally, hundreds of sites that describe the process but there are many directions you can go. First, what are you trying to accomplish? Build one board or develop a skill and make multiple boards? If you just want to build one board, then you might want to consider having a board house do it - sparkfun has a pretty good and cheap offering.
Before you make the board, you will need to have a design. I use eagle pcb layout software but there are many. there is a book by Al Williams that is pretty good - http://www.amazon.com/gp/product/007...83155&v=glance
There are at least 3 major methods once you have a design: toner transfer, photo and milling. Toner transfer uses a laser jet or copier to lay down the artwork and then heat is used to transfer it to the copper (google toner pcb). Photo uses photo-sensitized board that you expose an image of the board on and then develop it (just like a photograph, old style). google photo pcb. Milling uses a cnc machine to remove the the unwanted copper. Each has pros and cons. google milling pcb. photo and transfer use a chemical etchant to remove the unwanted copper.
By the way, reflow refers to a method of soldering surface mount components by heating up the board to "reflow" the solder (usually solder paste). Think of it as baking up a board... You don't need to worry about it. |
