Did you build the "3 axis stepper driver board" shown at the top of this page?
Tach42 3 axis board
If so, did you also build the 3-axis chopper board circuit shown at the bottom of that page?
If you did not build the chopper circuit, and you are using a higher voltage power supply than the motors' rated voltage, then it appears that you will need to add a "high wattage power resistor (sometimes referred as a ballast resistor)" to the circuit shown at the top of the page for each motor.
LinkBack URL
About LinkBacks
