Results 1 to 4 of 4
Thread: Using twisted pairs for the thick fingered.
    Oct 2005
    Long story short, what gauge wire can I use between the BOB and drives? Looking at the front panel switches to a computer I'm building shows much thinner than I'm using in my control box. What's the thinnest safe gauge for a signal wire?
    Dec 2003
    Personally for low current control wiring, I prefer 16g or 18g, many times, this may be overkill as far as current is concerned but it is far more nicer to put under terminals and crimp ends on etc than 20g and smaller.
    When using single conductor stranded I use TR64 as it has a high voltage rating but has a much thinner insulation that MTW or TEW etc, which make alot of difference in wire capacity when using wiring trough for example.
    In most cases wiring in the machine for servo's etc, do not skimp in gauge as it usually has to be in situations where flexing occurs.
    Oct 2005
    Thanks for the fast reply. I'm not so dumb then. I was thinking small would be a PITA at the terminal to clamp. A long time ago between health problems I won three G251 drives. I'm finally putting a package of computer and drives together. A complete package in a mid tower case. The disability has progressed to Quad classification now. Each wire I manage to get in place is a small battle, but it's progressing. Better than OT. At least I can see build progress for all the frustration.
    Jan 2009
    australia
    More power to you.
    Good luck
  1. twisted
    By riverracer in forum Mastercam
    Last Post: 07-06-2010, 07:47 AM
  2. How to make a twisted rope in wood?
    By PEU in forum WoodWorking
    Last Post: 02-20-2009, 10:51 AM
  3. Twisted wire pair for step & dir wiring?
    By patdttr225 in forum Gecko Drives
    Last Post: 04-09-2008, 10:27 AM
  4. Should steppers be wired with "twisted pairs"?
    By johnmac in forum Stepper Motors and Drives
    Last Post: 07-02-2007, 07:40 PM
  5. Twisted wires from motors
    By thuffner3 in forum Machine Problems, Solutions , Wireless DNC, serial port
    Last Post: 12-21-2003, 11:01 AM
