Old 02-01-2012, 09:30 PM
crosslakeguy is on a distinguished road
Question circiut design help, automatic run/stop 1axis
electronics help needed looking for a simple design so i push button, run to stop, then return to home stop. I am using stepper motor, I will provide pulses to drive motor, proper switches for both sides, 5v line level voltage, can use proper resistors to drive ic's. or cmos. or whatever is simpler. can do the signal inversion if needed? was looking at using a flip flop rs to run from home to end switch. the problem I have is it will cycle back and forth without stopping. so it needs to stop at the home position till the start button is pushed. maybe a nor? nand, inverter?? possibly could use a ne555 timer somehow? probly will use mechanical limits, but ? . what i need is a logic diagram or explanation of how to do it. My brain hurts, thought one of you could point me in the most sensible direction, maybe a single ic, a couple transistors? any help is appreciated. thanks, Steve
Old 02-01-2012, 10:46 PM
Al_The_Man's Avatar
Very simple using two small relays 1 P.B. and 1 N.C./N.O L.S. and 1 N.C. L.S.
The push button energize RL1 and will initiate run up to Stop, trip the N.C/N.O. LS and de-energize RL1 and pick up RL2 the motion will return to start and wait for P.B.
I can draw it up if you need it.
Tags
circuit boards
New Machine Build- Generic Emergency Stop (E-Stop) Design Concepts? zipzit General Electronics Discussion 8 06-09-2011 06:14 AM
New Machine Build- EMC2 E-stop parallel port pinout and E-stop loop GreenLead LinuxCNC (formerly EMC2) 12 08-03-2010 12:05 PM
Finding Engineering Design Software For Automatic Machine Design hellokitty General CAM Discussion 0 01-06-2008 12:39 AM
Where to find Schematic 1Axis Stepper controller (no software/PC) just manual switch? Calico General Electronics Discussion 9 01-02-2006 10:30 AM
Help w/ e-stop circuit design owhite General Electronics Discussion 4 03-07-2004 08:16 AM
