Results 1 to 6 of 6
Thread: encoder replacement
    Jun 2005
    encoder replacement
    I am looking to replace a dynapar encoder E1501000203 but can't find that # on dynapars site. does anyone know what I can use in it's place
    Jim
    Dec 2003
    Send an email to Dynopar support and ask for the resolution and type of the encoder, the physical aspects you can measure.
    Jun 2005
    Al
    Thanks for the response, I had actually done that prior to asking on the forum. I have not gotten a reply yet. I read their model # description but it seems to not work for my model. Hopefully they will get back to me soon.
    Dec 2003
    The E15 style does not show up in the cat. http://dynapar.com/uploadedFiles/_Si...010Catalog.pdf
    Is it like the E14 series? If so Koyo sell a practically identical one, it appears yours is a 1000p/rev, you just need to check if it is differential or single ended, (6 signal leads or 3)
    Jun 2005
    Al thanks for the reponse,
    It has 3 leads, What does that mean differential or single ended.
    Dec 2003
    ??? A simple 2ch quadrature encoder is 4 leads minimum, if differential, 6 leads min, more if the encoder has a 1/rev marker pulse.
    Unless you mean 3 leads PLUS 2 for power?
    1. Need Help!- Obselete encoder replacement
      By wahidbashir in forum Bridgeport and Hardinge Mills
      Last Post: 10-26-2010, 11:59 AM
    2. BEI encoder replacement
      By Goslowjimbo in forum Servo Motors and Drives
      Last Post: 10-09-2010, 08:34 PM
    3. encoder replacement
      By emxaler in forum Okuma
      Last Post: 02-24-2010, 02:50 AM
    4. encoder replacement
      Last Post: 02-20-2010, 12:03 AM
    5. Replacement Encoder Disc?
      By Jeshua in forum Servo Motors and Drives
      Last Post: 11-25-2009, 11:06 AM
