hi guys i have a router and the tb6560 board had enough - so i bought a new board to replace it - different manufacturer but still a tb6560 but looks more compact i have fitted it to power supply etc and plugged in - changed a few setting on mach 3 as instructed to by manufacturer - but all 3 axis more ok, via keyboard - except z axis when u press page up it goes down , but i can live with that - but also when i run a file i reset all the axis to 0 as i used to do - but now the motors seem to move quieter but a hell of a lot faster and it goes mental when trying to process the file - i tried drawing a simple circle to test, but it tried to go off the edge of the bed, and i said go 5mm deep and it went 20mm and would of gone deeper if it could - i am assuming its a mach3 setting issue can anyone shed any light on this many thanks karl |
| hi i can send you the pdf that came with it - so you can look but this is the one i bought - ive managed to tune the motor speeds down to what they were now - it just dont k now what to do when it starts eBay - The UK's Online Marketplace |
| hi on the bottom of the link on ebay it has a dip settings thing each axis has 6 switch,s every one is set the same, 1on , 2off, 3on, 4on, 5on, 6off would that info help?? i can email the pdf that came with the board - but its just the same text as on the ebay advert thanks for your time and help in this tho its really appreciated karl |
| It looks like with DIP switches 5 and 6 set to ON OFF the your board is doing half-stepping. With a standard 200 steps-per-revolution motor, that means you have 400 (half) steps per revolution. You need to use that number in conjunction with the details of your axis leadscrew (for example, how many turns per inch pitch it has) to figure out how many steps it takes to move the axis by one inch, and make sure that value is set inside Mach3 for steps per inch. |
#11
| hi i have been reading alot about my problems - and after messing around with a few settings i can now get it to cut what is on the screen - it was the pulse settings for the x axis - so we are getting somewhere but now i am having touble with m,ultiple passes - on the first pass it works fine but on the second it goes off - thanks again karl |
| need help with tb6560 board | terryt | General Electronics Discussion | 94 | 03-14-2012 12:08 AM |
| Need Help!- 4 Axis TB6560 to Mach3 Config ? ? | brutusgraphics | Controller & Computer Solutions | 3 | 07-08-2011 04:31 PM |
| Config settings help | tigman250 | Mastercam | 3 | 03-24-2011 07:21 AM |
| TB6560 Board. | Telly | Stepper Motors and Drives | 0 | 07-26-2010 12:32 PM |
| config settings for mach 2 | fidia | General CNC (Mill and Lathe) Control Software (NC) | 3 | 07-04-2007 05:18 AM |
