Old 11-02-2005, 10:56 AM
Kool Parts's Avatar
Kool Parts is on a distinguished road
Programmable Timer
There are lots of guys on this board designing, and building their own electronic boards and even cnc machines. I am not one of them I am hoping that in your travels though all of the electronic catalog's you have come across a "timer" like the one at the bott of the page in this link. (6LM70)
http://www.grainger.com/Grainger/wwg...se&CatPage=473
What I want is a programmable timer to turn on a motor (120 v 3amp) for so many min per hour, 24 hours a day for (at least) 14 days. Also 2 or 3 outputs would be helpful.
What I don't want is to pay $250 :frown: (cheap bastard) Normally grainger is higher than a cats back, so maybe its possible?
Thanks,
Gary
Old 11-02-2005, 04:07 PM
philba is on a distinguished road
Have you looked at Home Depot or Lowes? They have a number of timers that might fit your needs. The grainger ones didn't look that expensive (70 is not an unreasonable amount to pay for something like that).
Old 11-02-2005, 04:19 PM
Al_The_Man's Avatar
I don't know what part of the US you in, but there is something used north of a certain latitude called a block heater timer for automobiles, You may be able to pick those up cheap, but I am not sure if you can program multiple cycles over 24hrs, you may have to check on individual features.
Old 11-02-2005, 05:49 PM
Kool Parts's Avatar
philba,
Yes, I have tried all of the usual suspects. Kinda going in a different direction.
Actually the one in granigers is $253.00
Thanks,
Gary
Old 11-02-2005, 09:00 PM
HayTay's Avatar
HayTay is on a distinguished road
Lightbulb Link to modify a VCR into an automated cat feeder...
You may want to take a look at what James Larsson did to modify a used VCR into an automated cat feeder (Photos: From VCR to cat feeder). He took advantage of the programmable recording timer feature of the VCR. With a little ingenuity and some help from the CNCzone electronic gurus maybe this idea could be modified to control a TRIAC(?) (or three) that would in turn drive your 120V 3A motor(s). A used VCR and a few electronic components should be way less than $250.
Post your project if you decide to give it a try.
Have fun,
Harry
Old 11-02-2005, 10:32 PM
Megahertz is on a distinguished road
The surplus/salvage electronics store sells a coffee machine timer for $5.00. Here is the web link and some more details. The part number is MTC-3
http://www.allelectronics.com/cgi-bi...T-3&type=store
DIGITAL ON-TIMER
Digital timer from Mr. Coffee™. Small modular design, no brand name or logo. Ideal for use in any product that needs to be turned on automatically at a specific time. Operates on 120 Vac. Switch loads ups to 10 amps. Can be switched manually. White plastic face. 2.48" X 1.77", with four digit LED clock. Overall size: 2.48" X 2.17" X 1.88" deep behind face. 0.25" qc terminals. Easy to connect and operate. Includes instruction sheet.
Old 11-03-2005, 06:18 PM
Kool Parts's Avatar
NICE work Megahertz
Well opon further inspection it just turns on once a day. but nice link none the less.
Thanks,
Gary
Old 11-03-2005, 09:43 PM
Kool Parts,
I read your original post again and I see you want to turn on every hour and you would like 2 or 3 outputs. The solution is easy. There are 24 hours in a day; so you should buy 72 timers (24 * 3) are hook them up in triples and delay the time of each group of three by one hour. 72 * $5 = $360. Think of how cheep that is for all that computing power!!! Plus, the hours of time it would take to program and syncronize those timers, Jolly Fun.
Old 11-03-2005, 10:16 PM
One of Many is on a distinguished road
There are several OEM's that make these along the same lines.
One ebay example
Another
Another
Programmable would be nice, but cheap could get you by on a few cycle timers all daisychained together to cover 60min with an adjustable on time. It would be continuous recycle, not shutting off on the 14th day.
DC
Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade.
Old 11-04-2005, 10:23 AM
Kool Parts's Avatar
Megahertz,
That was the first thing one of the guys in the shop said! Of course there is a sump that needs cleaned.. And I'm going to ck out the cat feeder, I need one of those anyway
Gary
  #11   Ban this user!
Old 11-04-2005, 02:54 PM
Buy a cheap battery powered wall clock. ($15.00)
Glue a little bar magnet to the minute hand. ($1.00)
Glue two magnetic reed switches to the face of the clock at the appropriate minutes spacing and make sure that when the magnet passes them they close and re-open. (2 x $5.00 or less)
Buy a latching relay with a 12 volt coil and contacts able to handle your load.($15.00 or maybe a bit more)
Buy a cheap 12volt 500milliamp DC wall plug transformer. ($10.00)
Connect transformer through reed switchs to latching relay; first switch closing latches relay on, second switch closing latches relay off.
Run whatever you want from the relay contacts.
I've done it, it works to within seconds every hour.
  #12   Ban this user!
Old 11-09-2005, 10:26 PM
davesaudio is on a distinguished road
I wonder if what you want is in the capabilities of a lawn sprinkler timer?
between the zones and programmable times maybe....
or maybe put two cheap timers in series...
maybe...
