Old 10-26-2005, 10:35 PM
DJ Morrow is on a distinguished road
Power supply wiring help needed
I could sure use a little help assembling a power supply.
I have a couple of 24V, 10A LP-520 transformers, a 26,000uF capacitor and a bridge rectifier. I'd like to wire it all up to power my Gecko G201's and MGC 258 oz steppers. In bipolar parallel, the steppers are rated at 2.31 V and 4.20 amps.
Rather than trying to describe all the colors and numbers, I made up a small diagram. You'll see that I have arbitrarily supplied numbers to the wires on the transformers. So, hopefully, someone can tell me to connect wire #xxx to #yyy etc and when all is done, the smoke stays inside the parts.
http://www.ldrider.ca/CNC/powersupply.htm
Feel free to offer advice on whether my parts are properly matched, Series vs parallel, etc.
Looking forward to being enlightened.
Thanks everyone
David J. Morrow
Old 10-26-2005, 11:05 PM
widgitmaster's Avatar
Gold Member
widgitmaster is on a distinguished road
http://www.mcitransformer.com/i_notes.html
http://www.bright.net/~agarb/STMD/Power%20Supply.html
Hope this helps!
Eric A.A.
