I have a need for a temperature controller which will use a thermocouple as the setpoint and a different thermocouple as feedback. I have 2 heaters and I want the second one to follow the temperature of the first. I want to use a TC in the first one to determine the setpoint for the controller of the second one. I would prefer a discrete controller although PLC may be an option if necessary. I have a few vendors working on it but I'd appreciate any input regarding this type of controller, it seems none of the standard controllers have this ability. Thanks Matt |
| One of the biggest names in temp control is Omega, I believe they have an engineering dept that you can run you your requirements past them and see if they have anything off the shelf or suggestions. Al.
Agree with Al. Doing the same thing here for 10 machines. Expensive, but no messing around. |
| Omega is one of the ones working on it. Their best answer so far is a $650 PLC solution and then I have to buy a comms cable and write the control algorithm in ladder logic. I was hoping for plug and play as I don't have alot of time to get this project done. Matt |
2. Maybe you shouldn't have taken on this project if you don't have time to give it a proper solution. |
| 1. I was just stating the cost for general info, I don't think its expensive either. 2. If only I had the option. Building custom test systems on (relatively)short timelines is what pays the bills. That and putting out the proverbial fires. I'm somewhat of a perfectionist, borderline OCD about certain things. I'm not gonna short change the quality of my work due to a tight timeline, I just have to work more hours. ![]() I just got off the phone with Eurotherm. For a little more than Omega, they have a discrete controller which will take a TC input as a setpoint. Only a few parameters and a little labview style function block programming and I'm in business. I am already familiar with this family of controllers so the learning curve should not be too steep. Thanks for all the input Matt |
| CIB Industrial Control Interface | antsals | General CNC (Mill and Lathe) Control Software (NC) | 0 | 04-18-2011 05:51 PM |
| Problem- Temperature | rjsmith | CNC Swiss Screw Machines | 6 | 08-04-2010 10:57 PM |
| Head temperature | wildcat | Industrial Hobbies (Support forum) | 13 | 12-10-2006 04:33 PM |
| Looking for usage ideas for PLCs and other industrial control bits | Boilermakr | CNCzone Club House | 5 | 02-21-2006 08:26 AM |
| Using temperature as a fastner | pminmo | General Metalwork Discussion | 11 | 02-09-2005 03:36 PM |
