| The answer depends on factors such as the length of cable that you plan to use and the current rating of your motors. In general, I would not advise using CAT5 for motor wiring in most cases. The typical CAT5 cable designed for in-wall use has solid wire conductors, which are prone to breakage from vibration or flexing. Also, the wire gauge used in a CAT5 cable has a fairly small diameter (#24 AWG), which means that it is unsuitable for long runs when carrying anything other than a relatively small amount of current. You will probably want to use cable made from stranded wire, and probably using a wire gauge of #20 AWG or #18 AWG. Here is an example of such a cable from one vendor: CNCRouterParts |
| I use 22AWG, stranded, shielded alarm wire. I got 8 conductor wire so I can run all 8 wires for the steppers, even though with the commons, you can get away with less. I bought a whole box of 500' so have some to spare, if you are interested, I'd be happy to send you some at cost. Its $0.30 per foot plus $5 USPS Priority flat rate shipping. PM me if interested. Curtis |
| Mitsubishi wire type setting for zinc coated wire | Futurewire | EDM Machines | 1 | 01-26-2011 03:47 AM |
| Mitsubishi wire type setting for zinc coated wire | Futurewire | EDM Machines | 2 | 01-25-2011 06:49 AM |
| Wire size and type to steppers | TarHeelTom | Bridgeport and Hardinge Mills | 0 | 07-10-2010 06:56 PM |
| Wire EDM - Wire Type and Size | greenchair | General Metal Working Machines | 0 | 06-17-2009 01:44 PM |
| power supply size? for multi wire (total 250 inches of wire) | DanOSB | CNC Wire Foam Cutter Machines | 5 | 03-02-2009 04:34 PM |
