| Foam insulation (for car sound systems) will do the trick, but if the fans are standard PC case fans, you can pick up some really quiet ones off of newegg.com* May I recommend: Newegg.com - ENERMAX UC-8EB 80mm Case Fan These are the best, most reliable, quietest fans on Earth. If you buy any other 80mm fan, consider your money wasted. Save yourself a bunch of $ and just buy 3 or more. |
| Yep, I second the "quiet" fans. A good fan supplier catalogue should list the dB sound levels of each fan. Also, it is common for low CFM fans (lower air flow rate) to be quieter as they run as a lower RPM and lower power. |
| Noise reduction issue! | Barefootboy4 | Mach Software (ArtSoft software) | 0 | 09-15-2011 06:40 AM |
| Need Help!- Screeching Steppers Harmonic/Noise Reduction | catabolic | Stepper Motors and Drives | 11 | 07-12-2011 07:51 PM |
| Gear Reduction?? | Brass_Machine | General Metal Working Machines | 10 | 04-18-2011 08:20 PM |
| Porter cable spindle noise reduction or alternative? | paulr4 | DIY-CNC Router Table Machines | 6 | 03-26-2005 12:56 PM |
| 2:1 or 3:1 reduction...I'm not sure? | Bird_E | General Metal Working Machines | 5 | 08-18-2004 08:32 AM |
