Old 11-11-2011, 12:33 PM
accuracymark is on a distinguished road
Limit and Home Switch in Mach 3
Does anyone know if you can use only 3 switches (XYZ) for both limit and home switches in mach 3?
Old 11-11-2011, 01:09 PM
ger21's Avatar
Yes.
But, if you want to use them for both + and - limits, you'll probably need to mount the switch to the moving parts so that it can work at both ends of travel.
Old 11-11-2011, 08:29 PM
Originally Posted by ger21 View Post
Yes.
Or have 2 pins on each end of the travel. Same thing.
limit switch- home switch normd CamSoft Products 1 05-16-2008 06:56 PM
limit switch and home switch setup Runner4404spd General Electronics Discussion 0 12-15-2005 07:58 AM
Is it possible to use the home switch as the limit switch as well? Darc Mach Software (ArtSoft software) 2 10-23-2005 12:50 AM
Limit Switch / Home Switch in Software Sanghera General Electronics Discussion 6 11-01-2004 05:58 PM
