Old 11-05-2011, 10:41 PM
fordgt72 is on a distinguished road
Grounding Question
Was hoping to get some advice on grounding. I just started modifying an old PC case to house my...
1. Computer (Motherboard, PSU, CDROM, HDD)
2. Stepper Electronics (G540, PSU)
to clarify one PSU will power the computer and the other the driver.
Will I need to isolate the two PSU's? Or is this a bad idea altogether?
Somewhere I saw that someone had done the samething but I can't find it now.
I have a power jack similar to this. My thought was to mount the jack in the back of the case. Then run the "G" and "N" wires straight to the driver PSU and the "L" to a ON/OFF switch in the front of the case.
Here is where I get confused. The case is grounded by the computers PSU right? If I mount the driver's PSU to the case is it now grounded? Will having them both grounded cause issues?
Thanks ahead of time for any guidance.
Old 11-06-2011, 02:47 AM
doorknob's Avatar
doorknob is on a distinguished road
The computer's power supply is likely grounded to the computer chassis on both the AC line input side and on the DC output side.
The driver's power supply chassis is probably also directly connected to the G terminal on the AC line input. So by bolting the power supply chassis to the PC case chassis, you will be sharing that ground connection between the two power supplies. That ground is there for protection against possibly-dangerous wiring faults with the AC line. I do not expect sharing those grounds to cause any issues for you.
The negative terminal of the driver's power supply can be kept isolated from the chassis ground. It goes to the G540's negative power input (and to the limit switches).
Old 11-06-2011, 08:24 AM
doorknob,
Thanks for your reply. I was hoping I wouldn't have to isolate the driver PSU from the pc's case.
I really appreciate places like CNCZone. All the knowledge and great people that can be found here is just awesome.
Thanks again.
New Machine Build- Yet another grounding question. jwantulok General Electronics Discussion 1 12-11-2010 07:20 PM
Earth grounding question plain ol Bill CNC Plasma and Waterjet Machines 6 08-20-2008 02:41 PM
grounding question, PC case ground Fiero Addiction CNC Plasma and Waterjet Machines 2 08-16-2008 07:40 AM
Grounding question! GibbonsRock Automation Technology Products 3 07-21-2008 07:39 AM
Grounding question dmparrott General Electronics Discussion 2 08-23-2007 08:50 AM
