Old 11-02-2011, 01:46 AM
rthorntn is on a distinguished road
CNC 6040 home switches
G'day,
Disclaimer: I am completely new to CAM and CNC, I have no real electronics knowledge, I have got most of my info from this awesome forum.
Looking for some advice here or even a design or even for some lovely person on here to build me what I need (for a fee of course).
I have the Chinese CNC 6040 with a GeckoDrive G540 with a BOB and I want to have homing capability. The PC is running EMC2.
A 5m serial cable will be attached to the BOB in the G540 enclosure and I think the other end of the cable will go to a homing PCB.
I mean I know I need 3 environmentally sealed switches and maybe some other electronics (DB9 connector).
The list of stuff I don't know is alarming me!
The type of switches to use
Wiring the switches up
Placement of the switches
Any extra sticky out bits I need to help trip the switches
If only there was a kit for the 6040!
Thanks for looking and I hope somebody can help.
On the off chance someone is local, I am based in Sydney.
Cheers
Richard
Old 11-02-2011, 02:41 PM
bobsch's Avatar
bobsch is on a distinguished road
Have you checked out the thread on Hall-effect switches http://www.cnczone.com/forums/open_s...made_easy.html
They're a magnetically operated IC, totally sealed and easy to mount and wire.
Bob
"Bad decisions make good stories."
Old 11-03-2011, 01:25 AM
Thanks bobsch, thats a great thread.
But, the G540 is an issue with the hall-effect switches:
The G540 inputs are internally pulled up to 12V inside the unit, the switch closes, it needs to connect the input to 0V.
The G540 has a GC-04 breakout board in it.
http://www.homanndesigns.com/pdfs/GC-04R1.pdf
The 4 inputs of the G540 are connected to the top DB-9 connector on pins 1,2,3,4 respectively. Pins 6,7,8 on the same connector have 0V on them
So basically I need mechanical switches (or a separate PSU but I don't like the idea of another PSU).
Richard
Need Help!- Home switches and Limit Switches TheBulk DIY-CNC Router Table Machines 5 03-12-2011 05:08 AM
The relationship of limit switches to home switches. MikeAber General Electronics Discussion 4 11-04-2004 01:28 PM
Limit switches and home switches viktorcnc TurboCNC 2 08-03-2004 06:11 AM
home switches? ljoe1969 Xylotex 32 06-05-2004 01:57 PM
Home switches and limit switches. ynneb General Electronics Discussion 5 04-08-2004 05:32 PM
