Page 2 of 2 FirstFirst 12
Results 13 to 14 of 14
Thread: Need help with manual pulse generator
  1. #13
    Dec 2003
    The voltage looks fine.
    If you have a PC that runs DOS you could use this software to test them, I have input directly into the PP without the buffers shown with no problem.
    DRO SOFTWARE
    Sep 2006
    Thanks for all of the help, guys.
    I have it working. The pattern from the Wiki file is exactly how the Leds pulsed.
    The problem is either the "Mach Brains or the C-22 card"
    The pendant cable checks continuity on each wire, from pendant to db 25 connector.
    I took an old printer cable and spliced in to it for the A & B connection.
    Then ran wires directly from the USB connector 5+volt supply plug to the Hedds encoder.
    After configuring Mach " Port & pins", it will jog either direction on any axis.
    It's no bother to go to the keyboard to change axis. The MPG with a long cord, and an mobile E-stop is all I wanted anyway.
    Maybe later I'll set up some hot key buttons on the pendant to change axis, etc.
    Here is a couple of quick phone pics of my hillbilly hook-up:
    JAckal
    Everything is bio-degradable, if you run over it enough times with the lawnmower.
  1. Need Help!- Tickle Pulse Generator.
    By Tweakie in forum General Laser Engraving & Cutting Machine Discussion
    Last Post: 09-05-2010, 01:37 PM
  2. Manual Pulse Generator for K2CNC
    By Mike Stevenson in forum K2CNC
    Last Post: 09-03-2009, 04:23 PM
  3. Need Help!- Manual Pulse Generator
    By widgitmaster in forum General Electronics Discussion
    Last Post: 06-12-2008, 09:31 PM
  4. Adding a manual pulse generator to my home CNC
    By glentner in forum General Electronics Discussion
    Last Post: 10-01-2007, 10:30 AM
  5. Manual Pulse generator?
    By phantomcow2 in forum General Electronics Discussion
    Last Post: 07-23-2006, 11:10 PM
