Old 10-15-2011, 10:36 AM
jaydeep gajjar is on a distinguished road
Custom build controller for CNC mill
Hi there !
After a long time i am writing a new thread on cnczone. I am getting to start a new project for CNC control panel for mill. In past, i had built a 3-axis hobby CNC that can work on wood , controlled by PC (EMC2) through par port.
Now I want to design control panel like some smaller industry standard controllers and i have decided that i will not use par port (because many new PCs dosnt have one.)
i have enough knowledge of micro controllers(pic & arm7) and basic electronics.
i have two designs that are in my mind.
1. Use microcontroller and create its firmware.
> which have sd-card support to store g-code files.
> USB or ethernet support to transfer g-code files to control panel
remotely.
> create custom software that can start,stop or interrupt machine if
needed otherwise microcontroller run the machine alone without
need of computer.
Otherwise,
2 Put a low cost computer and design a PCI based IO card that can be controlled from Operating Software.
Please give some suggestions.
Thanks in advance.
Old 10-15-2011, 01:50 PM
doorknob's Avatar
doorknob is on a distinguished road
It might be useful to look at other designs to get some ideas.
For example, http://www.cnczone.com/forums/produc...ontroller.html (and CNC USB controller) and others.
Custom Build Laser with sukelaser.com ozlaser Laser Engraving & Cutting Machines 19 08-16-2011 10:42 AM
New Machine Build- Aluminun Extrusion Custom Build AZicuRN CNC Wood Router Project Log 8 07-28-2010 11:56 PM
Build Thread- Custom Pendant Build Prefect LinuxCNC (formerly EMC2) 0 04-19-2010 08:31 AM
Custom tapered end mill vendor? InspirationTool General Metal Working Machines 1 04-05-2007 11:24 AM
custom mini mill jimbo General Metal Working Machines 7 12-30-2004 10:33 AM
