Old 10-03-2011, 04:07 PM
JohnnyVegas's Avatar
JohnnyVegas is on a distinguished road
Need suggestion for Taig lathe DC motor
I have a used Taig lathe coming soon and am very excited. It has a single phase 1550 AC motor with it now (not the Taig OEM) and would like the ability to control the speed. I plan on modifying it to have Mach 3 sense the speed and, of course, CNC the unit in time.
Any suggestions on the size and type of DC motor to look for?
I've seen a lot of people finding and using tread mill motors. If I locate an old treadmill do I need the controller with it or just the motor???
www.digitalPimple.com
Old 10-03-2011, 06:26 PM
Al_The_Man's Avatar
If you want variable speed you need a controller, KB Baldor SCR or PWM drive, for fixed speed a full wave bridge across the 120vac.
Old 10-04-2011, 12:15 PM
Thanks. I can design and build a PWM so I guess I will start looking for a used treadmill in my area this week.
Thanks for the info.
What WATTAGE do the majority recommend or use for the Taig??
Is there any reason to have a speed greater then 1550 RPM??
New to metal working.
Old 10-04-2011, 12:53 PM
Al_The_Man's Avatar
Most of the Treadmill motors claim >2hp but I think that is a little over rated.
If you are lucky, you may find a T.M. with a Leeson with a 3hp 4000rpm.
Nice motors.
Need Help!- Suggestion on CNC lathe Jim Anderson Benchtop Machines 0 03-24-2011 11:56 AM
Need A Quote- Mini Metal CNC lathe suggestion Athaya Want To Buy...Need help! 3 02-08-2011 12:44 AM
Need Help!- Need suggestion what software or cam or ??? to use with lathe/turntable DanOSB CNC Wire Foam Cutter Machines 4 02-06-2009 12:49 AM
Looking for router motor suggestion for photo engaving GlacialWanderer DIY-CNC Router Table Machines 3 07-06-2008 03:17 PM
Taig lathe motor kong Mini Lathe 5 07-06-2007 07:45 AM
