Old 09-26-2011, 04:56 PM
Mach 3$ is on a distinguished road
new machine build
I have 3 en 208 drives and 3 mgm-340 servos. My question is using Ajax GPUIO4 & MPU11 BOARDS. How do I run my power (240volt) single phase to the Drives. Emerson says I need 30volts DC but nothing about ac power supply-side does this get hooked direct into the drives and how do I split the power so the drive only gets the right amount of amps I confused with incorporating the main power to the drives or is this what a transformer does. ANY INFO WOULD BE GREAT. and the software is Mach 3.
Need some direction to build a small machine to allow me to build a larger one Dman65 DIY-CNC Router Table Machines 1 07-28-2011 09:05 AM
I want to build a CNC Machine for PCB alexiscy Open Source CNC Machine Designs 7 07-25-2010 03:15 PM
Possible machine build DragonsBane74 General Metal Working Machines 6 06-01-2010 07:19 AM
Use the second machine to build the first! Madclicker CNC Wood Router Project Log 160 06-26-2007 11:29 PM
