Page 3 of 7 FirstFirst 123456 ... LastLast
Results 25 to 36 of 73
Thread: Power supply smoking -- HELP PLEASE!
  1. #25
    Registered john_100's Avatar
    Mar 2007
    uk
    as the data sheet for the S-350-48 doesn't indicate that it can be used in parallel , I would look at the PSP-300 supplies
    http://www.meanwell.com/search/psp-300/psp-300-spec.pdf
    Meanwell Power Supply Products
    otherwise why not use one power supply for one or two servo's
    depending on the load ?
    one thing to watch with multiple power supplies is the small leakage currents
    that can add up to a level that can give you an unexpected shock
    I've got the T shirt !!
    I would connect the common negative outputs to earth
    In the day job I have used and repaired switch mode power supplies
    that are "hot swoppable"
    the power supplies are designed to work in parallel and still
    work correctly when one is changed with the power on !
    http://www.trcelectronics.com/Meanwell/pdf/rcp1000.pdf
    John
    Attached Thumbnails Attached Thumbnails Power supply smoking -- HELP PLEASE!-servo_power_supplies.jpg
    Last edited by john_100; 09-24-2011 at 02:34 PM. Reason: add link to hot swoppable psu
  2. #26
    Jan 2005
    john_100
    There has been no trouble with this before, there are more than 2,500 packages sold & in use, put together with the 3/4 power supplies in parallel, no cap are needed
    Ideal is a Single power supply, Dmm is offering a single power supply, but the cost is almost double for a single 1000W power supply, To get a single 1000W power supply at the same cost as the 3 is the problem but is being worked on
    Mactec54
  3. #27
    Jan 2005
    firstyear
    I just did some numbers & you should only be using a max of ( 3 ) of these Power Supplies
    in Parallel, The fourth will be over load, your system is a 20amp max & with the ( 4 ) power supplies this will give you around 30amps
    Remove the fourth power supply & you will be running
    Mactec54
  4. #28
    Mar 2007
    uk
    Hi Mactec54 ,
    as you have proved with so many power supplies used in parallel
    Firstyear must be unlucky to have a faulty power supply
    even if a single 1000W power supply cost the same as three 350W supplies
    three power supplies that work in parallel would be the the better option
    keeping a spare 350W supply is less expensive ! If you need the machine
    for business and not a hobby
    John
    PS the circuit I posted was an alternative for any one
    that has power supplies that don't work in parallel
  • #29
    Sep 2010
    Mac, perhaps it would be useful to explain why you state 3pc 350watt power supplies are required to power 3pc 400watt power supplies on a cnc machine rather than 1 (I could argue that about 1pc rated about 600 watt max is the correct size).
    Mike (at) KilroyWasHere (dot) com -- servo/spindle/vfd motors/drives/controls sales/service/repair/retrofit
  • #30
    Jan 2005
    mike_Kilroy
    The peakpower for these 400W AC servo motors is around 800W, so Imax *48 = 800W, Imax = 16~17A
    So firstyear will need the 3 power supplies to run his system, could he use (1) power supply, yes at around 1000W would be about right for the job, but will cost a lot more for the (1) power supply
    Mactec54
  • #31
    Jun 2010
    New Zealand
    SOLVED!!!!
    mactec54, mike_Kilroy, john_100, Al_The_Man, TrickyCNC, doorknob and epineh
    First up I'd just like to say a massive thankyou to you all for all your help - You have given a newbie the courage to fix the problem with insight and knowledge beyond his hope and years!
    I bit the bullet, prepared for a sacrifical P.S; started from scratch and hoped for the best.
    sequence of events..
    * I hooked up 1 P.S only - all ok
    * I hooked up 2 P.S only - all ok
    * I hooked up the 2 P.S and bridged the 48VDC V+ & V- connectors - all ok - holy CR@P it's working!? ooooooh....
    * I hooked up the 3 P.S and bridged the 48VDC V+ & V- connectors - preapared for a bang, but nothing sweet nothing !! it's working!!!
    Even though I will only be using 3 P.S's....
    -With confidence riding high I hooked up the 4th P.S (now known as smokey the bandit) to the circut for sh/ts n giggles
    Called some help over expecting a bang and winced as I flipped the switch..and...
    it's working perfectly!!!!?????? WTF?
    it's humming along nicely
    Only thing I can say is that something was loose somewhere? We checked and tripple checked that nothing was loose the first time, but I guess we missed it??
    Here are the pics of all 4 working in parallel.
    After this hiccup I'm wondering if it's better to go for a single P.S? I have found a reasonably cheap one on Ebay.. It would be great if you could have a quick look at it and let me know what you think?
    eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
    I'd look at buying it and using the current 4 P.S's until it arrived (couple weeks) and then selling the 4 that I have. Might be able to break even?
    Attached Thumbnails Attached Thumbnails Power supply smoking -- HELP PLEASE!-4_front.jpg   Power supply smoking -- HELP PLEASE!-4_bridged.jpg   Power supply smoking -- HELP PLEASE!-setup.jpg
  • #32
    Jun 2010
    New Zealand
    Hi guys,
    The power supplies are all up and working, but make a buzzing noise - is that normal?
  • #33
    Sep 2010
    mike_Kilroy
    Good to hear you are up and running Firstyear!
    Ok on your design methods Mactec; I see now why you call for the higher wattage supplies. Like transformers, oversizing does not generally hurt, so your scheme of course works too; I'll leave it at that and back into the woodwork....
  • #34
    Jan 2005
    firstyear
    No they should not be making a loud noise that you can hear, unless the fans are running
    The 1000w power supply on ebay will only support a max of (4) of the servo motors, you would need 1400w to do the (5) axes set up you have
    I still think that you should only be running a max of (3) of the power supplies wired in Parallel as that is more than what you need to run the (3) XYZ Motors
    So take the 4th one out & see if they are still making the noise you are hearing
    Mactec54
  • #35
    Dec 2003
    Go with the Linear supply advice in post #24. You won't regret it.
    Especially with servo's.
  • #36
    Sep 2011
    One thing I don't see in this thread (did I miss it?) is, what are the motors rated at? voltage and current, please (or Watts if current missing)? The load is what determines the size of the power-supply.
  • Page 3 of 7 FirstFirst 123456 ... LastLast
    1. EDM (DIY) - PWM power supply question.
      By BenBenly in forum General Waterjet
      Last Post: 03-31-2011, 09:42 AM
    2. Power supply question
      By TarHeelTom in forum General Electronics Discussion
      Last Post: 03-13-2011, 05:22 AM
    3. Another power supply question
      By ranchak in forum General Electronics Discussion
      Last Post: 09-09-2007, 06:56 AM
    4. Power Dump glowing red and smoking on VF-1
      By GITRDUN in forum Haas Mills
      Last Post: 07-13-2007, 04:22 PM
    5. Power supply question
      By dandonegan in forum Gecko Drives
      Last Post: 11-26-2006, 12:49 PM
