Old 09-15-2011, 01:10 AM
LantonioA is on a distinguished road
Question Galil DMC-2143 - Red LED
Hi everyone!
I mistakenly applied 10.7V to the pin 63 (Reset) instead of sinking it to 0 (zero) volt, for a split second. Now the red LED is ON all the time and I can no longer communicate with the board. However it still has the same voltage reading that it used to have on all the 96 pins, except the X, Y, Z & W Amp Enable. Which makes sense: If there is a fault, all the axes should be disabled...
The reset pin goes straight to the IC U35 (see attached picture). Could anybody help me find this IC? It is smaller than a grain of rice and appears to be made by Texas Instruments. Since I overpower it, I will replace it first and go from there!
Any help will be greatly appreciated!
Luiz
Name:	U35 (70750 5CT C7LF).JPG‎
Old 09-15-2011, 02:25 PM
Al_The_Man's Avatar
Check out MAX708 micro version.
http://datasheets.maxim-ic.com/en/ds/MAX705-MAX813L.pdf
I have Galil boards that use the same IC and the schematic show the external reset going to this IC.
Old 09-16-2011, 10:23 PM
DMC-2143 U35
I downloaded their PDF! Is it a direct replacement for the ...C7LF...? How did you figured that?! The card works without it! If it has no other function, I will just leave it like it is!
Could you please sent me a copy of the schematics (Preferable DMC-2143), or let me know how I can get one?
Thanks a lot!!!
Luiz
Old 09-16-2011, 10:30 PM
Al_The_Man's Avatar
The schematic is for an older ISA card so it won't relate to the 2143, the card had the identical IC and the print was marked MAX708.
It only shows two connections to the chip, I can copy the page if you want.
Old 09-17-2011, 08:52 PM
Sure! Please send me a copy!
By what I've seen on the board, one track goes to the pin 63 and another one goes to the GL-1800. I couldn't tell if there are any other connections...
Thank you!
Old 09-18-2011, 09:42 AM
Al_The_Man's Avatar
PDF of MAX708 U2
Old 09-20-2011, 11:15 AM
Al_The_Man's Avatar
I reposted the PDF after I realized I had cut some of the copy off.
galil dcm 700 kevin swan Controller Cards 3 03-15-2010 04:25 PM
other than Galil bobk CamSoft Products 2 12-30-2009 04:39 PM
Yaskawa & Galil DMC 730 ChiTownTech Linear and Rotary Motion 2 11-06-2006 09:41 PM
Galil Anyone Al_The_Man Servo Motors and Drives 48 10-29-2006 01:52 PM
Sure Servo to Galil Mountain CamSoft Products 7 07-05-2006 12:40 PM
