Old 09-09-2011, 09:05 PM
Robert440 is on a distinguished road
Prolight 3000 turning center C-axis driver failure
I've encountered a problem with my Prolight 3000 turning center. I was learning how to use the machine by cutting a few tapered spacers when the machine buried the bit resulting in a stall. I cleared the machine and then the tool turret started acting erratically. It's very jerky as it rotates and it won't home correctly. I've been told by the factory that the driver is burned out and that they need to replace it. Is this something that I can fix by replacing a chip or is it much more complicated?
Thanks.
Name:	Prolight 3000 PCB.jpg‎
proLIGHT 1000 Machining Center problem Sethman Commercial CNC Wood Routers 2 12-27-2011 03:57 AM
Newbie- Prolight 3000 tool turret problem Robert440 Benchtop Machines 22 09-10-2011 09:00 AM
C-axis reference is lost in Mazak A16N turning center, due to table dismantling sonu Mazak, Mitsubishi, Mazatrol 0 12-24-2010 05:09 AM
Emcotronic driver board failure Adee Stepper Motors and Drives 1 05-13-2008 11:42 AM
Turning Center G40 G41 and G42 jorgehrr G-Code Programing 16 04-13-2007 10:48 PM
