Old 09-08-2011, 05:03 AM
deslee is on a distinguished road
cnc step/dir. cw/ccw
Can anyone please tell me what is the difference between this step/dir and cw/ccw on a stepper motor driver?because I dont know how to connect to the cw/ccw . please help
Old 09-08-2011, 08:20 AM
john_100's Avatar
john_100 is on a distinguished road
Hi Deslee
with step /dir
pulses to the step input makes the motor turn
the direction signal controls the direction (as expected)
with cw/ccw
pulses to the cw input turns the motor in one direction
pulses to the ccw makes it turn in the other direction
if you have the wrong control signals for a stepper driver
its possible to convert them
John
Name:	clock - direction and clock up-clock dowm.jpg‎
Old 09-09-2011, 06:11 AM
thanks john 100 I used the stp/dir bob to control cw/ccw driver ,nowander it did not work . so, do you have any kind of this schematic bob ,so I can make my own. hope to hear you so . thanks
Old 09-09-2011, 07:08 AM
john_100's Avatar
Hi Deslee ,
since my last post ,
I've looked at your other posts and had a look at the AD5410 manual
the circuit below should help
the AND gates made from part of the 7400 and 7406 IC's
can provide more current than a 7408 AND gate to drive the opto isolators
the 150 ohm resistor limits the LED current to a similar level to the "MF"
inputs
the step signal is switched to the CW or CCW depending on the
logic level from the direction signal
(note the NAND gate used to send the inverted direction signal to
one half of the circuit)
John
Name:	AD5410 step -direction converter.jpg‎
Old 09-09-2011, 09:18 AM
john_100's Avatar
Hi Deslee ,
I've just had a thought
you could use a 74241 octal buffer
only two of eight buffers are used
John
Name:	74241 step-dir to cw - ccw converter.jpg‎
Old 09-10-2011, 05:56 AM
Hi John,
does this mean i have to use 3 74241 to link it to my stp/dir bob?
so,i can use 3 drivers.
because i just have some basic electronics knowledge .thanks
Old 09-10-2011, 06:10 AM
Andre' B is on a distinguished road
Where are your step/dir signals coming from?
I believe EMC can be configured to generate cw/ccw directly.
Old 09-10-2011, 06:35 AM
john_100's Avatar
Hi Deslee,
yes you will need three 74241 IC's ( one for each axis)
the unused parts can not be used because each of the two enable pins
control 4 buffers
John
Old 09-11-2011, 04:48 AM
hello john
the circuit you give me is not working
I use it on kcam and mach3 no movement at all
any circuit I can try ? please let me know.
thanks.
stp/dir signals coming from parallel port.
what is EMC?
Old 09-11-2011, 06:47 AM
john_100's Avatar
I've not used EMC
but I understand its a LINUX version of the
the Kcam and Mach3 type of software for windows
have you used Kcam or Mach 3 to control another stepper
motor driver before?
if not try the step and direction test circuit from Geckodrive :--
Support
look in application notes-
open the miscellaneous tab
then open step and direction tester
I've added led indicators to the 74241 circuit
the direction signal should switch between the two led's
the step signal should make one flash on or off
john
Name:	74241 step-dir to cw - ccw converter+ leds.jpg‎
Last edited by john_100; 09-11-2011 at 07:03 AM. Reason: add link to geckodrive.com
  #11   Ban this user!
Old 09-11-2011, 07:01 AM
hi john
I did used kcam for the l297/l298 drivers
what do mean test circuit from geckodriver?
can you draw the led circuit for me?
thanks
  #12   Ban this user!
Old 09-11-2011, 09:48 AM
john_100's Avatar
Hi Deslee ,
it looks like you made your last post while I was re-sizing the picture of
the 74241 circuit with the two LED's added (one for CW and one for CCW)
the picture was too big when uploaded first time
the test circuit from Gacko was just incase you had problems
with the control of the printer port and the 74241 adaptor circuit
if you select in Kcam (or Mach 3) negative going pulses
one led should be on
the led will dim as you rapidly send pulses to turn the motor
for positive going pulses
the led will be off until , you send step pulses
the faster the pulses the brighter the led
you can test the 74241 circuit on its own ,with just a 5V supply connected
you should have one led on
connecting the direction input to 0V it should switch to the other led
connecting the step input to 0V will switch off the led
John
ID:	141745   Click image for larger version
Need Help!- Loosing step more and more on X axis only after reducing the accl/velocity step motor Calico DIY-CNC Router Table Machines 3 04-09-2010 07:23 PM
Need Help!- Step/Direction pins should be Step FWD and Step BACK rayscott Mach Software (ArtSoft software) 6 02-09-2010 05:57 PM
Full step and half step hybrid driver? rkremser Stepper Motors and Drives 4 11-20-2008 10:22 AM
Need Help!- How to edit MPFAN post file step by step m_bhui Post Processors for MC 2 10-04-2008 05:42 AM
Step by step cnc plasma with parts list and links. massajamesb CNC Plasma and Waterjet Machines 8 07-08-2007 10:22 PM
