Old 09-07-2011, 10:20 AM
woffler is on a distinguished road
Circuit explanation
Hi everyone i am trying to build a circuit here and i have a schematic on page 129 of the attached pdf manual .I tried to figure it out but i am lost ! it has a 74LS06 chip in it but from this i can not tell if there are three or one chip. I also am not sure what wires go to what pins on the thing .Could some one please lend a hand with this and explain this to me .
Old 09-07-2011, 10:22 AM
Sorry the file did not come threw i will try again.
Old 09-07-2011, 10:53 AM
I think i got it .
Old 09-07-2011, 11:00 AM
john_100's Avatar
john_100 is on a distinguished road
Hi Woffler
the circuit is using half of the 6 inverters in the 7406
John
PS they are open collector outputs , in some circuits you need a pull up resistor
from the +5v supply to the output
Name:	7406 pinout.jpg‎
Old 09-07-2011, 01:21 PM
Thank You
Thank's John i get it now ,i can see the pin out and how it work's thank you so much i can finally finish this project .
Old 09-07-2011, 01:42 PM
john_100's Avatar
if it helps I've re arranged the circuit
John
Name:	7406 probe circut.jpg‎
Old 09-07-2011, 03:32 PM
Smile
Hey John that help's a lot ,it will take no time at all to make this up now i would like to thank you for all your help you have been of great help to me on this and i am sure others will be grateful as well.
Old 09-08-2011, 04:51 PM
Hi John i have a question on the chip do i hook 5+ to the LA1 pin and LY2 pin and so on or do i need something on the Pin 7 and pin 14 to turn it on and off still trying to figure it out?
Old 09-08-2011, 06:35 PM
john_100's Avatar
connect the +5V supply to pin 14
and 0V (gnd) to pin 7
connect the 3 inputs to +5v ,via one of the three 2200 ohm resistors
( input 1 = pin 1 , input 2 = pin 3 , input 3 = pin 5 )
connect the probe to pin 1 (the first input)
link pin 2 to pin 3 and link pin 4 and pin5
connect the touch plate inputs and the B.O.B input to pins 2 and 3
the LED and 560 ohm resistor from +5v to pin6 (output 3)
the unused inputs (pins 13,11,9) can be left not connected
or connected to one of the supply pins (7 or 14)
see the diagram
John
PS with the 7406 open collector outputs it is safe for the touch plates
to short circuit pin 2 to the 0V (gnd / pin 7 )
Name:	7406  probe.jpg‎
Old 09-09-2011, 06:04 PM
We have Life
I finally got around to wiring it all together today and it works ! this would be a first for me. I would like to thank you John for all the help it sure made this a lot easier.
  #11   Ban this user!
Old 09-09-2011, 06:17 PM
john_100's Avatar
thats great
a successfull little electronics project
and a handy little tool for your machine
glad I could help
John
G17, G18 and G19 explanation please cossiegaz G-Code Programing 19 06-23-2009 04:44 PM
Need Help!- G41 and G42/40 explanation noshoesnoshirt G-Code Programing 3 05-09-2009 11:57 PM
g02 g03 explanation valmet58 CNCzone Club House 4 03-19-2008 09:36 PM
I need some explanation grebator Stepper Motors and Drives 0 04-04-2007 07:03 AM
G64 & G61 Explanation Please weaston G-Code Programing 1 01-31-2007 04:34 AM
