Old 08-28-2011, 03:00 AM
rutman is on a distinguished road
motor monitoring for fault detection
I'd like to have provision on my machine such that it cannot destroy itself.
Is there a known way to look at the motor currents and determine that there is a problem (e.g. from unusually high currents?)
Then on the mechanical side, perhaps I can use some replaceable component that has been designed to be the weakest link, such that in a real screwup the replaceable component breaks instead of something important (as in the 'ear' connecting a mountain bike derailleur to the bike)
Are there for instance couplers (e.g. motor shaft to screw shaft) that are designed to break at a certain torque?
Jeremy Rutman
Old 08-28-2011, 04:38 AM
john_100's Avatar
john_100 is on a distinguished road
Hi Jeremy ,
yes ,it all depends on the motor you want to protect
there is various mechanical fuses eg. shear pins or plastic gears that break
or slipping clutch torque limiters
for a mains powered ac motor you have a thermal overload switch
at least to switch off contactor
electronic speed controllers can either limit the motor current or switch off
depending on the overload current (and the design of the controller)
don't forget on cnc machines the limit switches to prevent you hitting the mechanical end stops
John
VMC15 fadal, 88HS error#9, spindle driver fault, servo amplifier fault kin73 Spanish CNCzone 3 05-17-2011 11:26 PM
Newbie- Stepper Motor fault ? hearty Stepper Motors and Drives 2 06-03-2010 03:39 PM
Problem- VF1 x motor z fault Fopec Haas Mills 6 03-29-2010 01:24 AM
C Axis Fault Motor Overload Error #27 wdwrd68 Fadal 6 10-10-2009 06:07 PM
Intermittent Spindle Motor Fault 18M homchz Fanuc 1 06-24-2009 06:11 PM
