09-27-2005, 03:28 PM
It should be OK. From the looks of the manual directions: ENCODER HOOK-UP
The encoder must be a digital quadrature TTL output type that operates on a single +5VDC power supply. The power
supply current rating must be less than 50 mA. It should be at least a 200 line encoder. If the encoder supply current is
more than 50 mA, use an external +5VDC supply. IMPORTANT: Connect a 470 ohm resistor from TERM. 6 to TERM.
7 if an external power supply is used for the encoder.
(TERM. 6) ENC- Connect the encoder power supply ground to this terminal.
(TERM. 7) ENC+ Connect the encoder +5VDC to this terminal
(TERM. 8) PHASE A Connect the encoder phase “A” to this terminal
(TERM. 9) PHASE B Connect the encoder phase “B” to this terminal | HEDS9000
These have no marker pulse, so homing may be an issue if that is part of the plan.
DC
__________________ Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade. |
