Results 1 to 8 of 8
Thread: Do stepper motors go bad????
    Registered Burnit0017's Avatar
    Nov 2009
    Hi, I am requesting help to resolve a problem with my Zenbot. Everything was working really well then the machine crashed. The stepper motor will not move and create a shuttering sound when there is the slightest resistance on any of the axis. I replaced the controller board with a new one, cleaned all the rails, and reset all the belt tensions but the problem still exists. Is there a solution to this problem? It is like the steppers are not producing enough power. There are other problems as well but I am trying to fix one thing at a time. Please help. I posted a private video on you tube to help show the problem. Thank you for any help received, this has really got me puzzled.
    http://www.youtube.com/watch?v=uaI2ZJMnfxI]DSCN0762 - YouTube
    Mar 2003
    Shelby Twp, MI....USA
    Are you sure it's not binding? With the power off, can you turn it by hand?
    Nov 2009
    Hi, yes with the power off it moves freely. With the power on I can stop it with my hand it has no holding torque. Are there gears inside the stepper motors?
    Mar 2003
    Try swapping motors from another axis.
    No, there are no gears in a stepper, and crashing, or staling them shouldn't harm them at all. Perhaps it's a wiring issue?
    Nov 2009
    Hi, all the stepper motors act the same. I checked the wiring it is all correct. It is acting like the stepper motors are not receiving enough current.
    Registered bobsch's Avatar
    Oct 2008
    Quote Originally Posted by Burnit0017 View Post
    Check the voltage from the power supply. Low voltage can cause the symptoms you describe.
    Bob
    "Bad decisions make good stories."
    Nov 2009
    Hi, checked the controller board power supply with a multimeter and no load. It is a 19 volt supply and the output was 19.36 volts dc. I am searching for some test leads and I check again under load. Thanks for the help.
    Oct 2005
    Check if it has yanked a wire when the machine crashed.
    A stepper motor with one wire disconnected will behave as you described.
    (edit) Sorry I just realised ALL your motors are weak. The fault must be something common to all motors, like the power supply (as people have said).
    Check your power supply voltage with the machine turned on and the motors powered up (but not moving).
    Also check the AC volts ripple in the output of the power supply.
    1. Stepper motors or ac servo motors?
      By JIM at ATG in forum Commercial CNC Wood Routers
      Last Post: 06-13-2011, 04:10 PM
    2. Need Help!- How hot should stepper motors get?
      By erkiwi in forum Stepper Motors and Drives
      Last Post: 07-17-2009, 03:22 AM
    3. Just IN- Provide controllers,drives,servo motors,stepper motors,electronic parts from China
      By Ling in forum Product and Manufacturer Announcements
      Last Post: 07-12-2009, 05:10 AM
    4. Wanted DIY stepper driver circuit for 6 wire stepper motors
      By Colin300 in forum Australia, New Zealand Club house
      Last Post: 09-20-2007, 10:20 PM
    5. stepper motors or servo motors?
      By jprobst in forum Torchmate
      Last Post: 07-13-2007, 06:37 PM
