Results 1 to 4 of 4
Thread: 600V 4A Fuse a replacement for 400V 4A
    May 2011
    us
    We have a dryer thats down because of a fuse and we need it up ASAP.
    We only have a 600V 4A delay fuse when the old one is a 500V 4A fuse.
    Is this okay since they are both 4A?
    Dec 2003
    As long as the open circuit voltage is less than 500v then it is OK.
    May 2011
    us
    Okay different fuse question.
    I have a 120 VAC to 24VDC Power supply.
    Omron S82K-05024 Power Supply 100-240VAC-24VDC/2.1 Amp | eBay
    Do I need to put a breaker or fuse on the 120 side going to the PSU or on the 24 VDC side coming off of it going to my terminal blocks for input and output devices. Or do I need both?
    This PSU has a a DC on and a DC Low3 light so I dont know if it has built in protection but would I still need to do the the above?
    Dec 2003
    I usually fit both, but the 120v side would be fused, minimum.
  1. Need Help!- Maatsura MC-600V-DC with Yasnac MX3
    By Jake E. in forum G-Code Programing
    Last Post: 05-24-2010, 07:03 PM
  2. Need Help!- Need step up transformer 120/400V 2HP
    By oxford in forum Want To Buy...Need help!
    Last Post: 03-18-2010, 11:11 PM
  3. Connect 200V servo motor to 400V drive
    By interflexo in forum Servo Motors and Drives
    Last Post: 04-15-2008, 02:34 PM
  4. Replacement for screw in fuse holders, F12 etc.
    By Mr. Technical in forum Bridgeport and Hardinge Mills
    Last Post: 07-19-2007, 08:57 PM
  5. G-201 fuse
    By Dylwad in forum Gecko Drives
    Last Post: 01-19-2005, 08:30 AM
