Old 08-22-2011, 09:40 PM
ZipSnipe is on a distinguished road
Capacitor testing question????
I have a circuit board that has 2 poly radial 100v caps next to each other of same value. I tested each one for cont., one gets a reading and the other doesn't. Then I tested all the caps on the board and most get no reading and I think about 2 or 3 do. Am I wasting my time on the caps while they are on the board or should I take them out?
Old 08-22-2011, 09:47 PM
Al_The_Man's Avatar
You didn't mention the value? Also you cannot check capacitors in circuit.
If testing larger values such as electrolytic's on ohms scale, the meter will indicate a reading as the cap charges off the meter.
A reverse reading will show when reversing the leads.
The bottom line is, a resistance meter is not a conclusive test for capacitors, unless they show a short or low resistance condition.
Drag force testing m/c/Friction factor testing m/c/Rotational resistance testing m/c chaitanya2102 Want To Buy...Need help! 0 03-08-2011 05:28 AM
Question about filter capacitor kae General Electronics Discussion 4 03-03-2009 09:14 PM
Power supply capacitor question Danno General Electronics Discussion 4 12-08-2008 06:38 PM
Transformer Capacitor Question KaptainKarst General Electronics Discussion 3 09-26-2005 04:56 PM
Another Capacitor Question bill south General Electronics Discussion 4 07-08-2005 10:17 AM
