Hello I just bought a grizzly G0602 10x22 lathe. I have it set up and changing spindle speeds is a real pain with the belt setup. I would like to replace the motor and make it variable speed. It comes with a 110v 1hp motor. I have 110v and 220v single faze in my garage. Ive searched this forum about different motors but theres so much information my brain started running out my ears. I would like to know what would be the best motor choice and why. A 3 phase motor and VFD, or a DC motor and SCR drive ? I need an RPM range from 150 to 2500. I do have a 2.6 HP @130v DC treadmill motor. What would be better to use for a spindle motor AC or DC and why? What about torque and HP drop off at lower RPMs? Thanks for any help or advice the more I search this forum on motor choices the more confused I get. |
| Generally a DC motor has maximum torque at zero rpm and tapers down slightly at the max rated rpm. HP is dependent on rpm. If you already have a decent DC motor, one of the KB or Baldor SCR drives should work, also improved rpm control can be obtained if the motor has a tach, as most of the SCR drives mentioned have the ability to input a tach. Al.
| I dont know of any site that does a comparison, but in general, any motor other than stepper has to have some kind of feed back to accurately control rpm, whether by simple monitoring current or as in a VFD by sensorless vector, the VFD without pulse generator or encoder loses accurate control at lower rpm. I have used DC servo's as spindle motors as they generally have tach feed back on them which gives accurate control down to really low rpm. Al.
| motor selection | Jack000 | DIY-CNC Router Table Machines | 20 | 04-14-2010 08:49 AM |
| Newbie- Motor selection ... | arvidj | Phase Converters and VFD | 2 | 02-07-2009 02:31 PM |
| Motor selection help? | Ben Colby | Bridgeport and Hardinge Mills | 0 | 05-24-2007 03:07 PM |
| VFD and motor selection | wildcat | Industrial Hobbies (Support forum) | 4 | 11-28-2006 02:35 PM |
| Motor selection | Konstantin | DIY-CNC Router Table Machines | 2 | 03-14-2004 12:08 AM |
