Results 1 to 2 of 2
Thread: Overload on VFD
    Mar 2008
    canada
    Overload on VFD
    Im trying to get my 5hp colombo spindles to run off a 7.5 hp Delta VFD055A23B. Im not having much luck and i may have cooked one. I believe i have it set properly, but instead of drawing the 12 Amps the spindle is rated for , its drawing 40!! The motor heats up and the overload trips on the VFD.
    The spindle is rated at 230 volt 3 phase, so im not sure what im missing. Its not a dual voltage spindle, at least i dont think it is but if any one has some answers for me to try, im all ears....i really dont want to cook my spindles!!
    Wade
    Sep 2010
    ok I'll shoot......
    if ur motor WERE dual volt and you tried running it as 460v winding on 230v vfd, it would pull low current so not likely this (and u said it is not a dual volt motor anyway).
    sounds like you got it set for VECTOR MODE instead of v/hz? can u chech parameter for that & make sure it is not in sensorless vector mode? dont go to it until you get good v/hz mode first.
    only other thing it could be is if you have v/hz curve set way off. so for more help, post all the data on your motor nameplate so folks can see if they see a mismatch?
  1. tripping the overload
    By machinehead1970 in forum General Electronics Discussion
    Last Post: 10-26-2010, 05:23 PM
  2. OVERLOAD #3
    By pertti in forum Fadal
    Last Post: 08-18-2010, 09:09 AM
  3. Need Help!- Takisawa SV Overload
    By testep in forum General Metal Working Machines
    Last Post: 08-05-2010, 03:10 PM
  4. Problem- Foam Overload
    By CORBIN92087 in forum General Metalwork Discussion
    Last Post: 02-03-2010, 05:53 PM
  5. 1987 LB 15 EC overload
    By Javy in forum Okuma
    Last Post: 09-27-2008, 06:51 PM
