Results 1 to 1 of 1
Thread: Current draw of 2 PNP sensors in series
    May 2011
    us
    I know I have saturated this forum but I got myself in a tough situation. This will be my last thread. But I have attached to JPEGs.
    My question for the first diagram is, if the PLC outputs are rated at 50Ma candle it handle powering this limit switch which has a current load of 0-200Ma?
    I KNOW MY JPEG SAYS 0-100Ma BUT I'M NOW LOOKING AT ANOTHER ONE.SORRY!
    My Last question is pertaining to the second diagram.
    Im I run a Photosensor, which has a Max output current of 250Ma, in series which the prox switch, How do I know the Photo Sensor wont draw too much current through the Prox switch? The prox switch specs only state the Load current,but I dont know how that applies to its max capacity. By the way Im doing this so that the when the door opens the prox switch will turn cut power to the Photo Sensor. I may not have authority to use the PLC so Im trying to figure out both ways to do it.
    Thank You.
    Attached Thumbnails Attached Thumbnails Current draw of 2 PNP sensors in series-current_draw_plc.jpg   Current draw of 2 PNP sensors in series-photo_draw_sensor.jpg
  1. Need Help!- working out the current draw of a stepper motor
    By geekinesis in forum General Laser Engraving & Cutting Machine Discussion
    Last Post: 01-26-2011, 06:56 AM
  2. stepper current draw
    By andrewbishop66 in forum Stepper Motors and Drives
    Last Post: 06-04-2009, 09:59 AM
  3. mach 3 monitoring current draw
    By eloid in forum DIY CNC Router Table Machines
    Last Post: 04-14-2009, 11:00 PM
  4. 3 Phase Current draw???
    By bherr in forum Bridgeport and Hardinge Mills
    Last Post: 08-06-2007, 04:16 PM
  5. gecko 210: low current draw?
    By anthony in forum Gecko Drives
    Last Post: 05-28-2005, 03:19 AM
