Old 08-08-2011, 11:19 AM
Skiroy is on a distinguished road
Prox switch/DC polarity circuit question
I have attached a Jpeg. If the polarity is such on the first figure at the Load 1, am I correct to assume how the polarity is when you add Load 2?
I am asking this because I have a negative(COM) connection coming out of a PLC that goes to the robot. It is a handshake signal that tells the robot to come and get a part. I am trying to put a 2 wire prox switch in series with it to stop the robot from getting the part unless there is a part present at the switch. The switch has a LED on it.
This got me to thinking. If this switch is in series with a negative -24 VDC wire how can it light up unless there is a negative and positive connection? I know this is elementary electronics question but I normally just replace parts not design them. The only way I can think this works is if my diagram is correct when adding L2 or Load 2.
Finally, the PDf spec sheet for this switch says its load current is 0-100Ma.
AK1-A0-2H Products
So does that mean I can run this switch in series before a photo sensor that is rated at an Output Max of 250Ma? Or does load current mean thats the 2 wire switches current consumption? If so what in the specs sheet tells me that is can handle other devices in series with it that draw more than 100Ma of current?
Really dumb Prox switch question dfmiller DIY-CNC Router Table Machines 5 05-12-2011 02:58 PM
Need Help!- Optical switch circuit? Fastest1 General Electronics Discussion 6 09-27-2010 02:48 PM
photoelectric switch circuit Malph General Electronics Discussion 8 05-18-2009 11:06 PM
Short circuit question Tomax General Electronics Discussion 12 04-29-2008 09:46 PM
Help Needed: Re: Lincoln IdealArc 250-250 polarity switch Jim6065 Welding, Brazing, Soldering, Sealing 4 01-18-2007 11:02 AM
