Results 1 to 3 of 3
Thread: No door saftey switches with 2 N.O.s?
    May 2011
    us
    Man, Its just one thing after another with this project. I think I got myself in over my head but I cant back down now. The robot arm alert system Im working on was designed to disable the photo sensor when the door is open. It has a laser and for operational and safety reasons the laser needs to shut off when the door is opened. The Robot already has a door safety switch that sends a signal to the robot so the robot will not move unless the door is closed.
    I assumed the 2nd set of contacts on the Omron safety switch was another set of N.O. terminals. After looking it up I see it is a set of N.C. terminals. And of course every single safety switch I see has more than one set of N.C. terminals but NONE have more than one set of N.O. terminals. This is getting aggravating.
    Can anyone help? I dont want to have to put a second safety switch on it and I looked in a 2 wire sink/source inductive switch but they say the load current is 0-100Ma. Im not sure if that is how much current it draws or if its how much current it can handle . I probably got this confused. But if I have this sensor in front of a device that draws up to 250Ma so that the device only receives voltage when the switch is closed, can this switch handle the 250Ma draw from the device when the switch load current is rated at 0-100Ma?
    Here is the switch
    AK1-A0-2H Products
    Jul 2011
    united states
    Question
    The safety switch (omron) is on robot panel. Right? so when door opens robot can move in and remove part. But when door closed it can't. Where does laser come in? If laser shuts off when door opens thru its own circuit, use the NC spare on the Omron as a set of dry contacts. In other words take your command signal for laser and run one leg thru Omron NC so when it opens door NC becomes open and laser shuts off redundant safety. Is this what your trying to accomplish???
    Dec 2003
    The load current is the rated current when the device is activated, so at whatever the supply voltage is the load has to restrict the current to 100ma max.
    Two wire do not generally have the capacity that open collector 3 wire type have.
  1. Hurco door safety switches
    By suntec in forum HURCO
    Last Post: 02-17-2011, 01:03 PM
  2. Saftey Door Switches
    By Scottjit in forum Safety Zone
    Last Post: 02-07-2011, 12:59 PM
  3. Need Help!- Wiring Saftey Stop and limit Switches
    By jandalaser in forum General Electronics Discussion
    Last Post: 06-12-2010, 03:05 PM
  4. Production Work Needed - EDM, Milling, Grinding *door to door free shipping*
    By FreedomTechUsa in forum Product and Manufacturer Announcements
    Last Post: 03-11-2010, 11:30 AM
  5. Bench grinder saftey
    By groovemixer in forum Toolgrinding & Toolgrinding Machines
    Last Post: 06-24-2007, 04:12 PM
