Old 07-12-2011, 03:41 PM
Vatorman is on a distinguished road
G540 with motion control Questions
Im currently running a g540 with mach 3 with no issues. I would like to know if I can run the warp 9 usb motion control interface with the g540 for more I/O and also is there any type of wiring schematics out there available showing these connections . Also will this help me in the long run as far as A reliability factor.
I also have 2 pc parallel ports and one not in use. Any suggestions would be great ?
Old 07-12-2011, 05:46 PM
ger21's Avatar
Yes. The Smoothstepper basically gives you two parallel ports. You'd just plug the G540 into one of them, and use the other for additional I/O.
If the parallel port is working for you, why not just use the second one you have?
Old 07-12-2011, 09:07 PM
The # 1 PP works fine with the g540 but the second one I added seems to give me some issues, I hooked up a c10 breakout board to add I/O and my pc would act funny, freeze up, not load, blue screen just figured motion controller might enhance the controller minus the second p port, at least thats what im thinking dont know that much about warp 9 product just looking for feedback and an idea to do it or not.
DB9/G540 questions JC50 DIY-CNC Router Table Machines 5 03-10-2011 05:03 PM
Newbie- Newbie questions on G540 LatheMaster Gecko Drives 1 12-21-2010 03:54 PM
Need Help!- G540 charge pump fault, no motion. Settings? JosephD Gecko Drives 8 06-16-2010 02:47 PM
A couple G540 questions blades Gecko Drives 7 01-24-2010 12:42 PM
G540 Questions Puppetworks Gecko Drives 3 10-22-2009 07:50 PM
