My shop has only single phase power, all our big 3 phase equipment we run off a 20 HP rotary phase converter. I would like to build the cnc router controller to accept only single phase so i dont have to worry about the wild leg which i know is there some days....and bad. My cnc has 2 variable speed 5hp spindles, a non variable 3hp spindle and a 4hp 3 phase motor that drives the drill bank. I am getting a VFD inverter for the variable speed spindles, but could i use the vfd for the non variable and use it just as a phase converter? Only one motor will be running at a time and i would set up a series of contactors controlled by the computer to switch them. Does this sound feasable or am i missing something? |
| I would only consider it if all the motors were the same type and configuration/rating. You normally set the parameters up for one particular configuration of motor, so mix and matching them may cause you to run into a few different problems. Even running two motors simultaneously off of one VFD, the motors should be the same and the rpm and load should not differ by more than 10% between each. Going with a make like WEG, you can get free engineering advice on their product usage. Al.
__________________ CNC, Mechatronics Integration and Machine Design. “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. Last edited by Al_The_Man; 07-10-2011 at 03:32 PM. |
| Problem- Inverter Units MIV | Antonio Arguijo | Okuma | 4 | 02-02-2011 07:50 AM |
| Inverter Problems | mikemill | General Metal Working Machines | 16 | 09-03-2010 07:30 AM |
| Inverter | vivagolf | DIY-CNC Router Table Machines | 0 | 11-03-2008 05:55 PM |
| Need Help!- Power inverter | beartrax | Fadal | 6 | 09-30-2008 10:10 AM |
| Inverter setup | multex1 | Phase Converters and VFD | 3 | 08-24-2007 09:56 PM |
