I'm getting ready to run wires from my Gecko 320x's to the servos. The servos are Electrocraft 90VDC 12A continuous & 20A peak. According to the Gecko FAQ's by Marcus:
http://www.cnczone.com/forums/gecko_...ers_servo.html This means run 16 gauge to the power on the Geckos. Then run 22 ga. wire from terminal 3 & 4 ( armature connections) to drive the servos. I'm not trying to contradict anyone, it's just that I prefer over-kill on things. Would it be better to run 14ga wire? Does it need to be shielded ? Can I just run regular stranded wire, and twist the pair inside of some flexible conduit ( separate from other wires of course)? Thanks for the info. JAckal
__________________ Everything is bio-degradable, if you run over it enough times with the lawnmower. |
| Al.
| Wire Size Question | l u k e | Phase Converters and VFD | 1 | 09-04-2010 05:36 PM |
| Picking a lathe size for servos I already have | Michael M | Servo Motors and Drives | 0 | 10-09-2009 01:30 PM |
| Via shape/size and wire size. | Drools | PCB milling | 0 | 08-14-2009 09:47 AM |
| Wire EDM - Wire Type and Size | greenchair | General Metal Working Machines | 0 | 06-17-2009 01:44 PM |
| power supply size? for multi wire (total 250 inches of wire) | DanOSB | CNC Wire Foam Cutter Machines | 5 | 03-02-2009 04:34 PM |
