I was told this motor could be but the data plate does not look promising. There are 6 wires coming out of it. Thanks Ken EDIT: The picture is not particurally clear so this is the data: VOLTS: 480 Style: Serial CYCLES: 60 Amps: 4/2 RPM: 1670 Type: 835 ( I believe) Service Factor: Rise Cont |
| The 6 wires are for 3 coils. If the coils are wired as a star configureation that means it is 3phase and neutral at the center point of the star making it 415 volts ( Or whatever your supply standard is.) If the coils are wired as delta ( A triangle) no neutral is used and it then becomes 240 volts ( Or whatever your supply standard is.) I will do a drawing for you if my words are not clear. Changing between Star and delta wiring will change the speed and torque of the motor though. Hope this helped. |
| Hi Benny, I'm lost !!!! The 6 wires are each white and numbered 1 thru 6 I see no diagram at all just the 6 wires. It is presently 480 volts. Dropping voltage will likely drop the HP from the .750 to the listed .375 , that is not much HP even for these big brutes. The bearings are also a bit noisy so I may be better off just looking for a 1 - 1.5 HP 3Phase 240 volt, they should not be all that much money for a used one. I want to run this with a VFD so I will need to keep to a 3 phase motor. Benny before you go to the trouble of drawing up a diagram let me look into getting another motor, if that does not work out then I will for sure need some help. Thanks much Ken |
| Too late I went to the trouble. Can you see that your motor has 3 sets of windings. obviously each set of windings have two ends. Hence the six wires. You will need to do a continuity test to establish each set of windings. You then wire it as the star setup as shown. In Australia our standard is 240/415 off the grid. I suspect your standard is 460 as you mentioned. Since you are going to buy a new motor you might as well try and wire it as suggested. It is a good idea to test the windings between the motor casing and the wires. There should be infinate resistance. If not, just bin it. |
