Old 06-26-2011, 06:24 PM
Mike4703 is on a distinguished road
Exclamation Interfacing MO-CON501/Little blue TB6560 manual controller
After I fried my Chinese TB6560 board, I decided to move on to installing Gecko 251X drivers. I still had the little blue manual control that came with the TB6560 board that was very convenient for moving the axis manually. I am also using it to test the new drivers. My main problem has been interfacing the MO-CON501 pendant controller with a driver. With help from people on the "How I fixed my Chinese TB6560 board" thread, especially Doorknob, I am continuing to come up with a plan for this. Right now continuing to check out interface board per Doorknob's instructions. I already found that the step pulses coming out are only about 1v amplitude despite the 5v supply voltage. This wouldn't step the TB660 board and probably not the Geckos either.
Old 06-28-2011, 12:16 AM
The problem should have been obvious
Finally got a break on the problem interfacing this MO-CON501. There is someone on here that has thousands of posts credited whos signature line says something about persistence making obstacles dissappear. I'm starting to realize that I may be the only one out here with this controller. After reading the documentation for the tenth time I noticed a diagram that showed an additional menu that is mentioned nowhere in the written instuctions--it allows the setting of the output pulse parameters in the software when the pendant is connected to a computer. This is what you get when instructions are translated from the Chinese. Whoever translated this had no idea that this might actually be important I guess. I'll let you know what happens after I get this thing reprogrammed. I mean WT @*!?
Old 06-28-2011, 08:35 AM
doorknob's Avatar
doorknob is on a distinguished road
That's good to hear.
As painful as it has been to get to this point, your insistent and persistent approach to troubleshooting this problem looks like it will finally pay off...
Old 06-30-2011, 07:34 PM
It Works! (Eventhough it shouldn't)
I finally had the time to get everything together for a test set up; Controller, drivers, and step motor. This is the controller that only had 1.6 v pulses coming out of it. I thought I could adjust the settings, but the documentation once again was misleading--no such menu actually existed in the controller. Didn't know what else to do but try it anyway--and it works. The attached pictures show the drivers mounted on my home made heat sinks and the test set up. The movie shows the pendant test using the x-axis output hooked up to my rotating table using manual move at a high setting and a low setting.
(Movie won't post--wrong format--I'll try again later)
Name:	2011-06-30 Drivers Mounted on heat sink1.jpg‎
ID:	137454   Click image for larger version
Name:	2011-06-30 Drivers Mounted on heat sink2.jpg‎
ID:	137455   Click image for larger version
Name:	2011-06-30 Test Setup.jpg‎
Old 06-30-2011, 07:51 PM
doorknob's Avatar
Did you convert the rotary table for stepper drive?
If so, do you have any photos of the conversion that you could share?
Old 06-30-2011, 08:27 PM
rotory table
Doorknob--this is a Sherline 4" rotary table that I bought "CNC ready" and put a stepper on later. So no--I didn't convert myself, just assembled it. I has worked really well--I used it hooked up to the TB6560 as a kind of lathe substitute, before I burnt it out. Turning the crank by stepper sure beats by hand.
Name:	2011-06-30 18.18.29.jpg‎
Old 07-02-2011, 01:35 AM
Compared Step Output with Scope
I put the scope on the interface board with the driver board connected and without it. Just reference to the interface board ground with no driver board connected, the output wave is not as sharp and the amplitude is a little over 1 volt (the scale is 0.4 volt per division in this measurement.) With the interface board connected to the driver board and again referenced to the interface board ground, measured at the drivers step input terminal, the wave form is very sharp and the amplitude is 3.5 volts (the scale is 1.0 volt per division in this measurement.) I don't know what made the difference here but I'm glad I didn't give up based on the first measurements. Next step here is to mount everything, set up limit switches, e-stop, power switch, assess need for optoisolation, thermal and over current protection, and not break anything in the process. Almost there?
Name:	Pendant board x axix step output.jpg‎
ID:	137539   Click image for larger version
Name:	Step Output connected to driver.jpg‎
Old 07-04-2011, 09:03 PM
H500 is on a distinguished road
I would guess that your driver is open drain. You won't measure anything meaningful from it until it is connected to something that pulls up the signal.
Out of curiosity, as you slowly increase the step rate from zero up to the maximum, does the motor sound noisier (vibrate) at any speed or is it smooth all the way? My system have several frequencies where it vibrate substantially. It would be interesting to see how carefully engineered drives like the Geckos behave with common motors.
Old 07-05-2011, 12:49 AM
I'll try it.
Thanks H500 for the info. I'll try the speed test you suggest and report back. Won't have time to start on it until next weekend though.
Old 07-08-2011, 05:25 PM
Speed/Smoothness Test
I ran the stepper from 1 rev/sec up to about 12 rev/sec and there is no change in vibration at any speed. The very slowest speed had minor vibration that can be smoothed out by adjusting a little pot on the board. It is smooth and quiet thru out the range. Also during this test I had the board and motor powered up for over an hour and the motor was only slightly warm to touch. I remember it getting much warming in a shorter period of time when I was experimenting with the TB6560 board.
  #11   Ban this user!
Old 07-09-2011, 09:36 PM
Interesting. If the motor is barely warm, it might mean that you are not driving the rated current into them. Are you getting enough torque?
My motor vibrates at around .5 rps when driven at the rated current. Otherwise, it's smooth until it reach the midband resonance speed.
  #12   Ban this user!
Old 07-11-2011, 02:47 PM
torque/optoisolation
I don't know if they are making full torque because I have no way to measure that and haven't used this setup yet to cut anything. It certainly seems to have enough torque just from watching it change speed and direction. The rotary table will jump when the direction changes suddenly and its a heavy little chunk of metal. By the way I am trying to setup optoisolation for this now. I don't need another breakout board. I don't believe these geckos have built in optoisolation and neither does the interface board for the controller. If anyone has recommendation for simple and effective isolation in this application let me know. In the meantime I am stopping to research this and may end up building my own.
Tags
direction, interface, mo-con501, step
How I fixed my Chinese TB6560 controller (updated) lasik2025 General Electronics Discussion 555 Today 01:41 AM
Mac 3 setup for TB6560 controller board davidarf General CNC (Mill and Lathe) Control Software (NC) 1 07-27-2011 02:31 AM
Burning up my TB6560 controller card for second time.... Vegabond General CNC (Mill and Lathe) Control Software (NC) 3 02-06-2011 07:04 PM
3 Axis TB6560 Driver Controller motor sizing crazydiamond Stepper Motors and Drives 4 01-05-2011 07:21 AM
TB6560 3-axis driver manual control kish89 Stepper Motors and Drives 4 12-08-2009 03:19 PM
