Old 06-13-2011, 04:21 PM
Inskeep is on a distinguished road
Question Turck 2 wire dc proxes
I have 6 Bi4-G12-ADZ32X proxes I would like to use for my x,y,z limits.
My question is would I handle these the same as npn device with resistor as specified in the CNC4PC bob manuals.
My deal is I am always trying to use what I have to save money.
It does not always work out so well.
Old 06-13-2011, 05:26 PM
Al_The_Man's Avatar
I show those as AC/DC types, but they appear to be 20v to 250v AC/DC, so you may be out of luck if you want to try them on a TTL input BOB.
Otherwise if they were the right voltage level they may be made to work on a TTL input.
Old 06-13-2011, 06:04 PM
vegipete is on a distinguished road
As Al writes, it does not appear from the catalog that these will work as you hope. The book indicates a 5 to 7 volt drop across the prox and a 1.7mA current when off. You could drive a relay with them though ...
Old 06-13-2011, 08:04 PM
Thanks for your help.
5 volt TTL is something I have never had to deal with.
Maybe you can teach a old dog new tricks.
again
Need Help!- Turck proximity sensors hacker7 DIY-CNC Router Table Machines 41 06-11-2011 10:23 AM
Mitsubishi wire type setting for zinc coated wire Futurewire EDM Machines 1 01-26-2011 03:47 AM
Mitsubishi wire type setting for zinc coated wire Futurewire EDM Machines 2 01-25-2011 06:49 AM
Running stepper motor wire with router wire? basskitcase DIY-CNC Router Table Machines 2 02-19-2010 10:18 AM
power supply size? for multi wire (total 250 inches of wire) DanOSB CNC Wire Foam Cutter Machines 5 03-02-2009 04:34 PM
