Results 1 to 3 of 3
Thread: Which encoder do I need?
    Sep 2006
    According to Mariss at Geckodrives I need an AMT 102, 103 style encoder.
    Looking at Digi-key, they show (2) different versions.
    102-1307-ND encoder #102 & 102-1308-ND encoder #103.
    AMT102 & 103 Rotary Encoders PTM parts list by Digi-Key and CUI
    Other than the mounting plate I can't see the difference.
    One says radial and the other axial? Which one do I need?
    Thanks,
    JAckal
    Everything is bio-degradable, if you run over it enough times with the lawnmower.
    Registered Bubba's Avatar
    Mar 2004
    LaGrange, GA USA
    The radial and axial refers to which way the wiring plug points. Which one you use depends on how YOU want the wires to be run. As for the actual encoder, they are the same.
    Art
    Sep 2006
    Thanks Bubba,
    So then it looks like the 103 fits under a smaller cover, with the wires sticking out parallel to the shaft.
    Thanks again,
    JAckal
  1. Broken BridgePort Encoder, Need new encoder or ServoMotor w/Encoder
    By TNBG_LTD in forum Want To Buy...Need help!
    Last Post: 03-22-2011, 10:20 PM
  2. Pin out for 19 pin encoder
    By dresda in forum Fanuc
    Last Post: 03-10-2011, 10:59 PM
  3. Encoder
    By Chriss F in forum Tree
    Last Post: 02-10-2009, 12:40 AM
  4. DRC Encoder
    By L Hong in forum General Electronics Discussion
    Last Post: 10-22-2008, 04:51 AM
  5. How to tell if my motor is Pulse encoder or quadrature encoder?
    By Darc in forum Servo Motors and Drives
    Last Post: 07-22-2005, 04:51 AM
