Old 06-06-2011, 07:10 AM
clock wheels is on a distinguished road
Help required. Measuring motor size for ones needs.
Can anyone out there help me out with a calculation to measure motor size for project needs. Like all of you I would like to build a mini mill, however I do not want to buy to large or to small of a motor for CNC needs.
Is there a calculation to work out size?
Clock wheels
Old 06-06-2011, 08:36 AM
wendtmk's Avatar
Moderator
wendtmk is on a distinguished road
This forum is for Little Machine Shop CNC machines. I would suggest asking this question in a forum more likely related to what you are looking for, like the General Electronics forum, or, if you are talking about a stepper or servo motor (hard to tell by what you posted), then either the Stepper or Servo forum.
Mark
Old 06-06-2011, 08:42 AM
Al_The_Man's Avatar
Thread Moved.
You can try the Kollmorgen free sizing program from their site.
Old 06-17-2011, 09:04 AM
Thanks guys for your help. I am new to cnczone and with so many subjects in CNC zone I was finding it difficult to pick the right area for my question. I will look in the areas as suggested by yourselves.
Old 06-17-2011, 07:28 PM
mike_Kilroy is on a distinguished road
did u find the kollmorgen motioneering program?
http://www.kollmorgen.com/en-us/supp.../motioneering/
did it solve ur questions? if not, ask some more!
Old 06-17-2011, 07:59 PM
Al_The_Man's Avatar
http://automationinmotion.com/images...7200416437.pdf
Servo Motor Sizing Concepts - 2009-06-15 06:00:00 | Design News
http://www.yaskawa.com/site/dmservo.nsf/link2/NKOE-7TKLD2/$file/PR.DN.01.pdf
Old 06-25-2011, 04:57 AM
Al & Mike you two guys are the ones to know.
Thank guys. I have just downloaded the Kollmorgen Motionengineering program. I just taken a quick look and what I see might do the job. At first sight the program just takes in information like the size of leadscrew/drag on slide and the length it will tavel and in return it should tell me the size of motor I will need. Have I got this right guys? Is this what it will do for me. If that what is does and I will be happy as a pig in mud or close to it.
Al, I have not looked at the other programs you have put me onto, however over the weekend I will find time. Only have time of a weekend to download emails and view sights.
Pete
Old 06-25-2011, 05:56 AM
yep, Motioneering will do as you say and pick a sample correct size motor for you. you can then enter YOUR motor data in a different screen to see how it fits with your mechanical data, but that is not usually required since it tells you what speed, what continuous and what peak torque you need as well as recommends inertia range.
Old 06-25-2011, 07:25 PM
Al_The_Man's Avatar
There is also this, p2 gives the formula's
Aerotech| Engineering Reference Motor Selection & Sizing
Size bolts required? 8020 adam_m DIY-CNC Router Table Machines 20 05-03-2010 08:35 AM
Measuring motor current sa1 General Electronics Discussion 1 09-14-2009 02:19 PM
Spot Size measuring? Pierke Laser Engraving & Cutting Machines 12 07-28-2009 04:04 AM
When do you stop measuring rapids in IPM and start measuring in G? slashmaster Benchtop Machines 10 07-08-2009 04:42 PM
stepper size required bru Stepper Motors and Drives 1 12-24-2006 02:38 PM
