Old 06-04-2011, 06:37 PM
Skiroy is on a distinguished road
question on Overload amps not matching motor draw
Okay so my Job has a filter dryer that keeps tripping the overload relay. My question is the thermal overload has a setting knob for the amps threshold, but it only goes up to 25 amps. But the compressor it is connected to says the nominal capacity is 14900w and the input voltage is 220V which it is actually getting 240V. But it says input is 5250w. So that means its normal amps it should be pulling is about 62 amps,right?
So isnt this overload relay way to small for the compressor motor?
Old 06-04-2011, 06:54 PM
Al_The_Man's Avatar
Is it actually a 20HP motor?
Is it fed from true 3ph or a RPC?
Old 06-04-2011, 08:20 PM
True 3 ph and Im not sureif it is a 20HP.
This is the dryer
EMAX
Old 06-04-2011, 11:12 PM
Al_The_Man's Avatar
You need to determine the FLA, Full Load Amps of the motor and if necessary put a clamp on meter on each phase in turn to measure the actual current draw, especially if this is a new occurrence not previously seen.
Old 06-05-2011, 09:46 AM
vger's Avatar
vger is on a distinguished road
I agree with Al on checking the amps in operation. The info sheet on that model says it should be 19 amps at 230 V. This will vary somewhat depending on a few conditions.
Refridgeration compressor head pressure being too high can cause over current.
Stopping and starting the Refridgeration compressor quickly can cause the compressor to stall causing VERY high current till the internal thermal protection kicks out.
Make sure the condenser coils are clean. If the fins are clogged, the head pressure will run high as the freon does not condense back to liquid as readily.
Steve
WATER-COOLE MOTOR SPINDLE 1.5KW AND MATCHING INVERTER maxloadio EBAY ADS 0 07-12-2010 02:29 PM
New Machine Build- Stepping Motor and Driver Matching Question waleed alhadidi Stepper Motors and Drives 3 01-17-2010 04:04 PM
Newbie- Matching different drive and motor size kumphanart Servo Motors and Drives 1 08-20-2008 05:02 PM
2.5 amps per phase drive - 2.8 amps per phase bipolar motor ... kochevnik Stepper Motors and Drives 6 10-22-2006 10:48 PM
motor mixing and matching... charleyy DIY-CNC Router Table Machines 8 09-05-2004 11:32 PM
