Old 05-31-2011, 04:19 PM
ceencee is on a distinguished road
understanding servo motor specs
Here are the specs off my servo motor. Im trying to find a driver to drive this dc servo. Can anyone give me some insight in what all this means.
Nmax 2000 rpm ...................... Vmax 176 Volts
Cn 5,5 Nm ............. In 6,5 A ............ Ke 0,85 Vsec/rad
Cp 30 Nm ............ Ip 35,5 A.............. Kt 0,85 Nm/A
IM B5............ IP 54
20 volt/1000.............. IMAX 0,200 A
Any help would be appreciated to decipher this motor.
Thank-you in advance
Old 05-31-2011, 04:32 PM
Al_The_Man's Avatar
If requiring max. rpm, you will need a power supply of 176volts+min10%.
To operate at a constant torque of 5.5Nm will require a supply capable of 6.5A.
The Max current/torque before motor damage is 35.5amps at 30Nm, which ideally should not be seen and limited by the drive.
The 20v/1000 I assume is a tach, which is not now generally used with modern torque mode drives.
The mode of control, step/dir or analogue etc, will determine the type of drive you use, I believe Largen Viper drives fall into this range.
With a Tach, I assume this is a DC brushed motor?
Need Help!- IMC Servo Motor specs jjobezo Servo Motors and Drives 2 09-06-2009 01:32 PM
servo motor specs eloid DIY-CNC Router Table Machines 1 03-04-2009 12:34 AM
SM-1 Servo motor specs tjs88yj HURCO 6 03-26-2008 10:06 AM
servo motor specs and help cowanrg Servo Motors and Drives 3 06-11-2005 06:11 PM
Understanding (European) motor specs - help WoodSnarfer Servo Motors and Drives 3 01-16-2005 04:13 PM
