Old 05-22-2011, 05:27 PM
Jackal66 is on a distinguished road
Question about running power to my machine
This is about the power from my breaker box to my Hurco mill.
I will have some of the wiring on the mill 120v & some 220v ( all single phase).
My idea of combining it through the same wiring is in the following pic:
Name:	wiring receptacle to machine.jpg
I know this will work and my concerns aren't local electrical code, but will this be ok for the machine as far as grounding and everything else?
I didn't want to run a 120v extension cord and then have the 220v on another circuit.
This way there will be (1) breaker marked "Hurco".
The reason I'm using 6-3 wire is because it is already here.
Thanks,
JAckal
Everything is bio-degradable, if you run over it enough times with the lawnmower.
Old 05-22-2011, 05:56 PM
Al_The_Man's Avatar
Normally the power is taken to the Mill enclosure and then the wiring, fusing, transformation etc is done in the enclosure.
Why are you doing it the way you show?
Is there any reason not to follow a similar practice than the original, or an adaption of of it?
I am assuming this is a retrofit?
There is nothing wrong in principal with what you suggest but I would suggest you feed the enclosure with 240 1 ph and then split off with a suitable fusing etc to the 120v 1 ph circuits etc.
Old 05-22-2011, 06:39 PM
Yes, it is a retrofit.
I was just showing it in basic ( layman's terms), so there would be no interpretation errors.
It has a main disconnect switch. Everything goes in there first, then in the main cabinet.
There will be a 120 volt plug inside for powering my CPU.
There are others I have seen personally that used 10-3 wire, and ran (1) leg of the 120v with the bare ground for the common.
Just checking to make sure this is acceptable before doing. It seems a lot of people's problems are from grounding, or lack there-of.
Some people think ground and common are the same.
Jackal
Old 05-22-2011, 08:03 PM
Al_The_Man's Avatar
Jackal
Yes, unfortunately ground is used a bit indiscriminately to mean a any common, without a particular reference as to whether it is earth ground for example.
Circuit for running a driver as a power feed? Greenbuggy General Electronics Discussion 1 02-13-2011 06:34 PM
Need Help!- Star SR32 Aux power for running air jet solenoid? pneumadyne CNC Swiss Screw Machines 4 09-16-2010 01:03 AM
Any benefits running 220 instead of 110 to my power supply? mattbesquare General Electronics Discussion 3 02-20-2010 08:08 PM
Need Help!- How can I get my machine up and running?! silverblown02 Bridgeport and Hardinge Mills 7 02-23-2008 11:03 AM
Question about +5V from pc and running wires DAB_Design General Electronics Discussion 2 01-05-2005 09:58 AM
