| Encoder - Decoder I have a few stepper motors that have encoders one one side of them, Does anyone have a schmatic or know where to get a 3 chanel encoder interface board for around 100$ Do most Encoder interfaces use serial, parrelle or ISA/PCI?? |
| Most 3 channel encoders are quadrature output (2 channels) and an index channel. The quadrature output (channel A and channel B) have the following output (CCW): A 0011001100.. B 0110011001.. The CW output is the reverse: A 0011001100.. B 1001100110.. These outputs are usually decoded by a quadrature decoder to give a "step" and "direction" output (or CLK and U/D signal for counters). The index channel gives a single output pulse once a revolution and is generally used to give an accurate "home" position. Mariss |
| Hello bcromwell You may build simple 8 bit up/down counter using standart CMOS IC and you can read the counter outputs from the PC paralel port.(You must write simple software) CHA feeds the UP/Down input, CHB feeds the clock input. This method use the shaft encoder in x1 mode. |
| encoder issues | rutexus | Servo Drives | 13 | 05-21-2006 07:49 PM |
| What's your max distance to encoder? | murphy625 | General Electronics Discussion | 5 | 05-12-2005 11:57 AM |
| Encoder output into 2 different inputs? | murphy625 | Servo Motors and Drives | 2 | 03-23-2005 10:36 AM |
| Need encoder recommendation | Swede | General Metal Working Machines | 9 | 10-05-2004 09:01 PM |
| Encoder wiring | balsaman | Gecko Drives | 15 | 12-30-2003 12:01 PM |
